6ba812c8b193df42eeb5de9ab7cfb35d
014a61d5
014a61d5
Miguel Felipe Silva Vasconcelos
Module 2 Exercise 3 - plots
cc18009f
3
3 changed files
56 additions
69 deletions
+56
-69
exercice_python_en.org
module2/exo3/exercice_python_en.org
+56
-69
module2/exo3/histogram.png
+0
module2/exo3/simple_plot.png
+0
014a61d5
#+TITLE:
Your title
#+TITLE:
Module 2 Exercise 3 - Data visualization
#+AUTHOR:
Your name
#+AUTHOR:
#+DATE: Today's date
#+LANGUAGE: en
#+LANGUAGE: en
@@ -11,84 +11,71 @@
@@ -11,84 +11,71 @@
* Some explanations
* Reading input
Creating the data structure to store the following numbers:
#+begin_src
14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9,
https://orgmode.org/guide/.
18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1,
13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9,
12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0,
13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1,
13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1,
14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8,
8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4,
16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0
print("Hello world!")
array = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9,
16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
: Hello world!
* Source for creating the graphs
[[https://matplotlib.org/2.0.2/users/pyplot_tutorial.html][matplot
tutorial's page]]
C-c~.
* Creating the histogram
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
#+begin_src python :results output file :session *python* :var matplot_lib_filename="histogram.png" :exports both
from matplotlib import pyplot as plt
plt.figure(1) # the first figure - we need this, otherwise the plots will overlap
plt.hist(array)
plt.title('Histogram')
plt.axis([0, 25, 0, 25])
[[file:./cosxsx.png]]
[[file:histogram.png]]
transparent and reproducible.
* Creating the plot
#+begin_src python :results output file :session *python* :var matplot_lib_filename2="simple_plot.png" :exports both
plt.figure(2) # the second figure
plt.plot(array)
understandable on GitLab.
plt.title('Simple plot')
plt.axis([0, 100, 0, 25])
plt.savefig(matplot_lib_filename2)
print(matplot_lib_filename2)
followed by ~Tab~.
[[file:simple_plot.png]]
014a61d5
8.7 KB
014a61d5
54.4 KB
