715d998f42c58555b2fbdb5aca4064cb
1c3036cc
1c3036cc
Update exercice_python_fr.org
852bb21f
17 additions
80 deletions
+17
-80
module2/exo2/exercice_python_fr.org
+17
-80
1c3036cc
#+TITLE:
Votre titr
e
#+TITLE:
Calcul Simpl
e
#+AUTHOR:
Votre nom
#+AUTHOR:
Guilain Leduc
#+DATE:
La date du jour
#+DATE:
21 juillet 2020
#+PROPERTY: header-args :eval never-export
+PROPERTY: header-args :session :exports both
@@ -11,83 +11,20 @@
@@ -11,83 +11,20 @@
* Quelques explications
document.
print("Hello world!")
data= np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
print("Moyenne : ", round( data.mean(),2))
: Hello world!
print("Min : ", round(min(data),2))
print("Max : ", round(max(data),2))
print("Médiane : ", round(np.median(data),2))
print("Ecart-Type : ", round(np.std(data, ddof=1),2))
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
: Moyenne : 14.11
: Min : 2.8
: Max : 23.4
: Médiane : 14.5
: Ecart-Type : 4.33
\ No newline at end of file
compréhensible sur GitLab.
