74a384058fe452f679f08e5f0fe15e8b
14453e5e
Commit
14453e5e
by
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Version anglaise de M2/exo5 pour Python/Orgmode
parent
9a8977a2
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
217 additions
and
0 deletions
+217
-0
exo5_python-en.org
module2/exo5/exo5_python-en.org
+217
-0
No files found.
0 → 100644
View file @
14453e5e
#+TITLE: Analysis of the risk of failure of the O-rings on the Challenger shuttle
#+AUTHOR: Arnaud Legrand
#+LANGUAGE: fr
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
#+HTML_HEAD: <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
#+HTML_HEAD: <script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/js/bootstrap.min.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
#+LATEX_HEADER: \usepackage{a4}
#+LATEX_HEADER: \usepackage[french]{babel}
# #+PROPERTY: header-args :session :exports both
On January 27, 1986, the day before the takeoff of the shuttle /Challenger/, had
a three-hour teleconference was held between
Morton Thiokol (the manufacturer of one of the engines) and NASA. The
discussion focused on the consequences of the
temperature at take-off of 31°F (just below
0°C) for the success of the flight and in particular on the performance of the
O-rings used in the engines. Indeed, no test
had been performed at this temperature.
The following study takes up some of the analyses carried out that
night with the objective of assessing the potential influence of
the temperature and pressure to which the O-rings are subjected
on their probability of malfunction. Our starting point is
the results of the experiments carried out by NASA engineers
during the six years preceding the launch of the shuttle
Challenger.
* Loading the data
We start by loading this data:
#+begin_src python :results value :session *python* :exports both
import numpy as np
import pandas as pd
data = pd.read_csv("shuttle.csv")
data
#+end_src
#+RESULTS:
#+begin_example
Date Count Temperature Pressure Malfunction
0 4/12/81 6 66 50 0
1 11/12/81 6 70 50 1
2 3/22/82 6 69 50 0
3 11/11/82 6 68 50 0
4 4/04/83 6 67 50 0
5 6/18/82 6 72 50 0
6 8/30/83 6 73 100 0
7 11/28/83 6 70 100 0
8 2/03/84 6 57 200 1
9 4/06/84 6 63 200 1
10 8/30/84 6 70 200 1
11 10/05/84 6 78 200 0
12 11/08/84 6 67 200 0
13 1/24/85 6 53 200 2
14 4/12/85 6 67 200 0
15 4/29/85 6 75 200 0
16 6/17/85 6 70 200 0
17 7/2903/85 6 81 200 0
18 8/27/85 6 76 200 0
19 10/03/85 6 79 200 0
20 10/30/85 6 75 200 2
21 11/26/85 6 76 200 0
22 1/12/86 6 58 200 1
#+end_example
The data set shows us the date of each test, the number of O-rings
(there are 6 on the main launcher), the
temperature (in Fahrenheit) and pressure (in psi), and finally the
number of identified malfunctions.
* Graphical inspection
Flights without incidents do not provide any information
on the influence of temperature or pressure on malfunction.
We thus focus on the experiments in which at least one O-ring was defective.
data = data[data.Malfunction>0]
data
#+end_src
#+RESULTS:
: Date Count Temperature Pressure Malfunction
: 1 11/12/81 6 70 50 1
: 8 2/03/84 6 57 200 1
: 9 4/06/84 6 63 200 1
: 10 8/30/84 6 70 200 1
: 13 1/24/85 6 53 200 2
: 20 10/30/85 6 75 200 2
: 22 1/12/86 6 58 200 1
We have a high temperature variability but
the pressure is almost always 200, which should
simplify the analysis.
How does the frequency of failure vary with temperature?
#+begin_src python :results output file :var matplot_lib_filename="freq_temp_python.png" :exports both :session *python*
import matplotlib.pyplot as plt
plt.clf()
data["Frequency"]=data.Malfunction/data.Count
data.plot(x="Temperature",y="Frequency",kind="scatter",ylim=[0,1])
plt.grid(True)
plt.savefig(matplot_lib_filename)
print(matplot_lib_filename)
#+end_src
#+RESULTS:
[[file:freq_temp_python.png]]
At first glance, the dependence does not look very important, but let's try to
estimate the impact of temperature $t$ on the probability of O-ring malfunction.
* Estimation of the temperature influence
Suppose that each of the six O-rings is damaged with the same
probability and independently of the others and that this probability
depends only on the temperature. If $p(t)$ is this probability, the
number $D$ of malfunctioning O-rings during a flight at
temperature $t$ follows a binomial law with parameters $n=6$ and
$p=p(t)$. To link $p(t)$ to $t$, we will therefore perform a
logistic regression.
import statsmodels.api as sm
data["Success"]=data.Count-data.Malfunction
data["Intercept"]=1
# logit_model=sm.Logit(data["Frequency"],data[["Intercept","Temperature"]]).fit()
logmodel=sm.GLM(data['Frequency'], data[['Intercept','Temperature']], family=sm.families.Binomial(sm.families.links.logit)).fit()
logmodel.summary()
#+end_src
#+RESULTS:
#+begin_example
Generalized Linear Model Regression Results
Dep. Variable: Frequency No. Observations: 7
Model: GLM Df Residuals: 5
Model Family: Binomial Df Model: 1
Link Function: logit Scale: 1.0
Method: IRLS Log-Likelihood: -3.6370
Date: Fri, 20 Jul 2018 Deviance: 3.3763
Time: 16:56:08 Pearson chi2: 0.236
No. Iterations: 5
coef std err z P>|z| [0.025 0.975]
Intercept -1.3895 7.828 -0.178 0.859 -16.732 13.953
Temperature 0.0014 0.122 0.012 0.991 -0.238 0.240
#+end_example
The most likely estimator of the temperature parameter is 0.0014
and the standard error of this estimator is 0.122, in other words we
cannot distinguish any particular impact and we must take our
estimates with caution.
* Estimation of the probability of O-ring malfunction
The expected temperature on the take-off day is 31°F. Let's try to
estimate the probability of O-ring malfunction at
this temperature from the model we just built:
#+begin_src python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both :session *python*
data_pred = pd.DataFrame({'Temperature': np.linspace(start=30, stop=90, num=121), 'Intercept': 1})
data_pred['Frequency'] = logmodel.predict(data_pred)
data_pred.plot(x="Temperature",y="Frequency",kind="line",ylim=[0,1])
plt.scatter(x=data["Temperature"],y=data["Frequency"])
plt.grid(True)
#+end_src
#+RESULTS:
[[file:proba_estimate_python.png]]
As expected from the initial data, the
temperature has no significant impact on the probability of failure of the
O-rings. It will be about 0.2, as in the tests
where we had a failure of at least one joint. Let's get back to the initial dataset to estimate the probability of failure:
#+begin_src python :results output :session *python* :exports both
print(np.sum(data.Malfunction)/np.sum(data.Count))
#+end_src
#+RESULTS:
: 0.06521739130434782
This probability is thus about $p=0.065$. Knowing that there is
a primary and a secondary O-ring on each of the three parts of the
launcher, the probability of failure of both joints of a launcher
is $p^2 \approx 0.00425$. The probability of failure of any one of the
launchers is $1-(1-p^2)^3 \approximately 1.2%$. That would really be
bad luck.... Everything is under control, so the takeoff can happen
tomorrow as planned.
But the next day, the Challenger shuttle exploded and took away
with her the seven crew members. The public was shocked and in
the subsequent investigation, the reliability of the
O-rings was questioned. Beyond the internal communication problems
of NASA, which have a lot to do with this fiasco, the previous analysis
includes (at least) a small problem.... Can you find it?
You are free to modify this analysis and to look at this dataset
from all angles in order to to explain what's wrong.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
