no commit message
parent ef41b83f
......@@ -2,17 +2,75 @@
"cells": [
"execution_count": null,
"execution_count": 8,
"execution_count": 9,
"ename": "SyntaxError",
"evalue": "invalid syntax (<ipython-input-9-b3fb4d8933e8>, line 2)",
"output_type": "error",
"traceback": [
"\u001b[0;36m File \u001b[0;32m\"<ipython-input-9-b3fb4d8933e8>\"\u001b[0;36m, line \u001b[0;32m2\u001b[0m\n\u001b[0;31m Mon ordinateur m'indique que $\\pi$ vaut *approximativement*\u001b[0m\n\u001b[0m ^\u001b[0m\n\u001b[0;31mSyntaxError\u001b[0m\u001b[0;31m:\u001b[0m invalid syntax\n"
"Mon ordinateur m'indique que $\\pi$ vaut *approximativement*\n",
"execution_count": 10,
"3.141592653589793\n"
"from math import *\n",
"print(pi)"
"execution_count": 7,
"evalue": "invalid syntax (<ipython-input-7-a12ad2cb2fed>, line 2)",
"traceback": [
"\u001b[0;36m File \u001b[0;32m\"<ipython-input-7-a12ad2cb2fed>\"\u001b[0;36m, line \u001b[0;32m2\u001b[0m\n\u001b[0;31m Mais calculé avec la __méthode__ des [aiguilles de Buffon](https://fr.wikipedia.org/wiki/Aiguille_de_Buffon), on obtiendrait comme __approximation__ :\u001b[0m\n\u001b[0m ^\u001b[0m\n\u001b[0;31mSyntaxError\u001b[0m\u001b[0;31m:\u001b[0m invalid syntax\n"
"source": []
