"A method that is easier to understand and does not make use of thesin function is based on thefact that if $X \\sim U(0, 1)$ and $Y \\sim U(0, 1)$, then $P[X^2 + Y^2 \\le 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X \\sim U(0, 1)$ and $Y \\sim U(0, 1)$, then $P[X^2 + Y^2 \\le 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
