Update toy_document_en.Rmd
parent d200d14e
title: "Your title"
title: "À propos de pi"
author: "Your name"
date: "Today's date"
date: "25 Oct 2023"
output: html_document
......@@ -10,24 +10,39 @@ output: html_document
## Some explanations
## Asking the maths library
My computer tells me that $\pi$ is approximatively
pi
## Buffon’s needle
Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the approximation
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
## Using a surface fraction argument
```{r pressure, echo=FALSE}
plot(pressure)
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1]=\pi /4$ (see [“Monte Carlo method” on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
set.seed(42)
N = 1000
library(ggplot2)
It is therefore straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1 :
4*mean(df$Accept)
\ No newline at end of file
