Completed toy_document_fr.Rmd
parent 2d2a8d3f
......@@ -28,7 +28,7 @@ theta = pi/2*runif(N)
## Using Fraction arguement
A method that is easier to understand and does not make use of the sin function is based on the fact that if X∼U(0,1) and Y∼U(0,1), then P[X2+Y2≤1]=π/4 [Mont carlo method](https://en.wikipedia.org/wiki/Monte_Carlo_method). The following code uses this approach:
A method that is easier to understand and does not make use of the sin function is based on the fact that if $X\sim U(0,1)$ et $Y\sim U(0,1)$ then $P[X^2+Y^2\leq 1] = \pi/4$ [Mont carlo method](https://en.wikipedia.org/wiki/Monte_Carlo_method). The following code uses this approach:
set.seed(42)
