Commit 5e554026 authored by David Elser's avatar David Elser
version1
parent 496f742e
title: "Your title" title: "CO2 Keeling"
author: "Your name" author: "David Elser"
date: "Today's date" date: "05-03-2021"
## Data preprocessing fetch the Data file and check if file already exists
The data is available from the Web site of the Scripps Institute "https://scrippsco2.ucsd.edu/data/atmospheric_co2/primary_mlo_co2_record.html"
```{r setup, include=FALSE} Soure script available at : https://github.com/DemirhanOzelTrojan/Keeling_Predict/blob/master/main.R
knitr::opts_chunk$set(echo = TRUE) install.packages('forecast', dependencies = TRUE)
``` install.packages("imputeTS")
## Some explanations install.packages("imputeTS")
library(forecast)
library(imputeTS)
When you click on the button **Knit**, the document will be compiled in order to re-execute the R code and to include the results into the final document. As we have shown in the video, R code is inserted as follows: ```{r}
data_url = "https://scrippsco2.ucsd.edu/assets/data/atmospheric/stations/in_situ_co2/monthly/monthly_in_situ_co2_mlo.csv"
data_file = "CO2.csv"
```{r cars} if (!file.exists(data_file)) {
summary(cars) download.file(data_url, data_file, method="auto")
It is also straightforward to include figures. For example: Skip the frist 5 lines of the file
plot(pressure) data = read.csv(data_file, header=TRUE, skip=5)
Let's have a look at what we got:
head(data)
tail(data)
Since the results are not stored in Rmd files, you should generate an HTML or PDF version of your exercises and commit them. Otherwise reading and checking your analysis will be difficult for anyone else but you. ```{r}
data$X.ppm.[data$X.ppm. == -99.99] <- NA
data$X.ppm. <- na.interpolation(data$X.ppm.)
head(data)
tail(data)
