8c19b8aa9b3e351f2427cf306117b1dd
cb236b7c
cb236b7c
David Elser
final
5e554026
2
2 changed files
151 additions
10 deletions
+151
-10
exercice_en.Rmd
module3/exo3/exercice_en.Rmd
+151
-10
exercice_en.pdf
module3/exo3/exercice_en.pdf
+0
cb236b7c
title: "CO2 Keeling"
title: "CO2 Keeling
Curve and Hisitorical Ice Core Data
author: "David Elser"
date: "05-03-2021"
output:
html
_document
output:
pdf
_document
## Data preprocessing fetch the Data file and check if file already exists
The data is available from the Web site of the Scripps Institute "https://scrippsco2.ucsd.edu/data/atmospheric_co2/primary_mlo_co2_record.html"
#### Please note that I am not a Computer Scientist and my programming skills are very limited.
### Data preprocessing fetch the Data file and check if file already exists
"https://scrippsco2.ucsd.edu/assets/data/atmospheric/merged_ice_core_mlo_spo/merged_ice_core_yearly.csv"
Soure script available at : https://github.com/DemirhanOzelTrojan/Keeling_Predict/blob/master/main.R
install.packages('forecast', dependencies = TRUE)
install.packages("imputeTS")
install.packages("tidyverse")
### Load librarys
library(ggplot2)
library(forecast)
library(imputeTS)
library(lubridate)
### Fetch CO2 measurements from Mauna Loa observatory, Hawaii, USA
data_url = "https://scrippsco2.ucsd.edu/assets/data/atmospheric/stations/in_situ_co2/monthly/monthly_in_situ_co2_mlo.csv"
@@ -29,23 +42,151 @@ if (!file.exists(data_file)) {
Skip the frist 5 lines of the file
### Fetch Ice Core CO2 Data
data_url = "https://scrippsco2.ucsd.edu/assets/data/atmospheric/merged_ice_core_mlo_spo/merged_ice_core_yearly.csv"
data_file1 = "Ice-CO2.csv"
if (!file.exists(data_file1)) {
download.file(data_url, data_file1, method="auto")
### Skip the frist 36 lines
data_ice = read.csv(data_file1, header=FALSE, skip=36)
### Skip the frist 5 lines of the file
data = read.csv(data_file, header=TRUE, skip=5)
Let's have a look at what we got:
### Let's have a look at what we got and check NA
head(data_ice)
tail(data_ice)
na_records = apply(data_ice, 1, function (x) any(is.na(x)))
data[na_records,]
### Conversion of decimal-date into Years, rename V2 into ppm
data_ice$date<- format(date_decimal(data_ice$V1), "%Y")
head(data_ice)
tail(data_ice)
names(data_ice)[names(data_ice) == "V2"] <- "ppm"
data_ice$Year=as.numeric(data_ice$date)
head(data_ice)
tail(data_ice)
### Let's have a look at what we got from Mauna Loa observatory and check NA
head(data)
tail(data)
data[na_records,]
### impute data of column X.ppm..4(CO2, seasonally filled,adjusted filled)
data$X.ppm.
[data$X.ppm.
== -99.99] <- NA
data$X.ppm.
<- na.interpolation(data$X.ppm.
data$X.ppm.
.4[data$X.ppm..4
== -99.99] <- NA
data$X.ppm.
.4 <- na.interpolation(data$X.ppm..4
head(data)
tail(data)
### data preparation
data.ts <- ts(data$X.ppm..4, start = c(1958, 1), end = c(2021, 1), freq = 12)
### split training and testing data, use 90% of available data in the co2.csv file
train.test.split <- 0.9
split.index <- round(length(data.ts) * train.test.split)
### train time series
data.train.ts <- window(data.ts, start = c(1958, 1), end = c(1958, split.index))
### test time series
data.test.ts <- window(data.ts, start = c(1958, split.index + 1), end = c(1958, length(data.ts)))
### create a fit using the time series
fit <- ets(data.ts, model = 'AAA')
### forecast using the fit
predictions <- forecast(fit, 12 * 20, level = 0.95)
## Plot Ice Core Data
theme_set(theme_minimal())
ggplot(data = data_ice, aes(x = Year, y = ppm))+
geom_line(color = "#00AFBB", size = 1)
## Plot predictions till 2025
plot(predictions,
main = '',
xlab = 'Time',
ylab = 'CO2 (ppm)',
xlim = c(1958, 2025),
shaded = TRUE,
shadecols=c('light blue'))
legend('topleft',
legend=c('Historical Data',
'Predicted Data',
'95% CI'),
fill=c(NA, NA, 'light blue'),
col=c('black', 'blue', NA),
lty=c(1, 1, NA),
lwd=c(1, 2, NA),
border=c(NA, NA, 'black'),
inset=0.01)
cb236b7c
File added
