Commit 9c6219f1 authored by cristobalcarreno's avatar cristobalcarreno
no commit message
parent d6c9e7c4
......@@ -76,7 +76,7 @@
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0, 1)$ and $Y\\sim U(0, 1)$, then $P[X^2 + Y^2 \\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
