Update toy_document_en.Rmd
parent 7df973fa
title: "YA our title" title: "A propos du calcul de PI"
author: "Your name" author: "Eléazar Ndodje"
date: "Today's date" date: "05 Août 2021"
```{r setup, include=FALSE}
## Some explanations
```{r pressure, echo=FALSE}
plot(pressure)
