9099067849846ce05e5895bd6223ad64
c4a706fa
c4a706fa
Noukben17
exo3 fait
6a20949f
28 additions
64 deletions
+28
-64
exercice_python_fr.org
module2/exo3/exercice_python_fr.org
+28
-64
c4a706fa
#+TITLE:
Votre titr
e
#+TITLE:
Réaliser un affichage graphiqu
e
#+AUTHOR:
Votre nom
#+AUTHOR:
Benoit NOUGNANKE
#+DATE:
La date du jour
#+DATE:
2021-10-27
@@ -11,83 +11,47 @@
@@ -11,83 +11,47 @@
Quelques explications
Import data
#+begin_src python :results value :session :exports both
df = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
df
document.
** Sequence
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
print("Hello world!")
: Hello world!
plt.figure(figsize=(10,5))
p
ersistance d'un bloc à l'autre (et on l'exécute toujours en faisant
p
lt.plot(df)
~C-c C-c~).
plt.tight_layout()
plt.grid()
import numpy
x=numpy.linspace(-15,15
plt.savefig(matplot_lib_filename
print(x)
[[file:/tmp/babel-UEAKId/figureVflCg6.png]]
** Histogramme
plt.
plot(x,numpy.cos(x)/x
plt.
hist(df
plt.tight_layout()
plt.tight_layout()
plt.grid()
[[file:./cosxsx.png]]
[[file:/tmp/babel-UEAKId/figurekC2sYx.png]]
compréhensible sur GitLab.
