Replace toy_notebook_fr.ipynb
parent 1e10682d
"cells": [ "cells": [
"# 1 À propos du calcul de π\n",
"## 1.1 En demandant à la lib maths\n",
"Mon ordinateur m’indique que π vaut *approximativement*\n"
"execution_count": 9, "execution_count": 11,
"outputs": [ "outputs": [
"name": "stdout", "name": "stdout",
"output_type": "stream", "output_type": "stream",
"text": [ "text": [
"test42\n" "3.141592653589793\n"
"source": [ "source": [
"print(\"test42\")" "from math import *\n",
"print(pi)"
"## 1.2 En utilisant la méthode des aiguilles de Buffon\n",
"execution_count": 12,
"3.128911138923655"
"import numpy as np\n",
"np.random.seed(seed=42)\n",
"N = 10000\n",
