Commit 890291e8 authored by Margaux Lefebvre's avatar Margaux Lefebvre
graphs exo 3
parent 4349577b
......@@ -4,30 +4,36 @@ author: "Votre nom"
date: "La date du jour"
output: html_document
```{r setup, include=FALSE}
## Data
On met les datas dans un vecteur
## Quelques explications
data<-c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
## Sequence plot
xvalue<-1:100
total<-data.frame(xvalue, data)
library(ggplot2)
ggplot(total, aes(x=xvalue, y=data)) +
geom_line(color="royalblue")+
xlab("")+ylab("")+theme_bw()+xlim(0,100)+ylim(0,25)
## Histogramme
```{r pressure, echo=FALSE}
plot(pressure)
xvalue<-1:100
library(ggplot2)
ggplot(total, aes(x=data)) +
geom_histogram(bins = 10, fill="royalblue",color="black")+theme_bw()
#+xlim(0,25)+ylim(0,25)
