52d79842
52d79842
Konrad Hinsen
Get rid of Python-related warnings
04a7d392
2
2 changed files
10 additions
2 deletions
+10
-2
init.el
module2/ressources/rr_org/init.el
+3
-1
init.org
module2/ressources/rr_org/init.org
+7
-1
52d79842
@@ -13,7 +13,7 @@
setq
org-babel-python-command
if
memq
system-type
windows-nt
ms-dos
"Python"
"python3"
"python3
-q
;; If the Python and R executables are on your system's search path,
;; you should not have to modify anything here. If Emacs does not find
@@ -257,3 +257,5 @@ Entered on %U
add-hook
'org-babel-after-execute-hook
'org-display-inline-images
add-hook
'org-mode-hook
add-hook
'org-mode-hook
'org-babel-result-hide-all
setq
python-shell-completion-native-enable
nil
52d79842
@@ -36,7 +36,7 @@ document, simply =M-x org-babel-tangle=.
(setq org-babel-python-command
(if (memq system-type '(windows-nt ms-dos))
"Python"
"python3"))
"python3
-q
@@ -431,3 +431,9 @@ To use this type <B and then TAB. This comes with a session argument
(add-hook 'org-mode-hook 'org-display-inline-images)
(add-hook 'org-mode-hook 'org-babel-result-hide-all)
** Optimizing Python execution
*** Don't use readline completion
This often fails, yielding an ugly warning, and isn't of any use in Org-mode anyway
#+begin_src emacs-lisp :tangle init.el
(setq python-shell-completion-native-enable nil)
