a5c9bbaf
a5c9bbaf
Konrad Hinsen
Instructions for proxy configuration in init.[el|org]
9613dd19
2
2 changed files
57 additions
3 deletions
+57
-3
init.el
module2/ressources/rr_org/init.el
+29
-2
init.org
module2/ressources/rr_org/init.org
+28
-1
a5c9bbaf
;; Machine-dependent configuration - adapt as required for your computer!
;; Executables for Python and R
;; There are two kinds of settings that might have to be adapted to the
;; specific environment of a computer:
;; 1. Telling Emacs which executables to use for Python and R
;; 2. Telling Emacs to use a Web proxy
;; Default setting: Use "python3" under Linux and macOS, but "Python" under Windows.
;; The default for R is "R" for all platforms (predefined by Emacs).
setq
org-babel-python-command
@@ -23,6 +29,27 @@
;; R
;; (setq inferior-R-program-name "C:/Program Files/R/R-3.5.1/bin/x64/Rterm.exe")
;; If your local network imposes the use of a Web proxy, you must uncomment and adapt
;; the following lines. Emacs does NOT use system-wide proxy settings. In most
;; cases, only the first two lines (proxy-name and proxy-port) need to be changed,
;; but sometimes the fifth line (no_proxy) also requires modifications. If you are
;; unsure what the right settings are, ask your local network administrator for help.
;; (let* ((proxy-name "proxy.mynetwork.org")
;; (proxy-port "8080")
;; (proxy-name-port (concat proxy-name ":" proxy-port))
;; (proxy-url (concat "http://" proxy-name-port "/")))
;; (setq url-proxy-services (list (cons "no_proxy" "127.0.0.1")
;; (cons "http" proxy-name-port)
;; (cons "https" proxy-name-port)))
;; (setenv "http_proxy" proxy-url)
;; (setenv "https_proxy" proxy-url)
;; (setenv "JVM_OPTS" (concat "-Dhttp.proxyHost=" proxy-name
;; " -Dhttp.proxyPort=" proxy-port)))
require
'org
require
'ess-site
a5c9bbaf
@@ -23,8 +23,14 @@ document, simply =M-x org-babel-tangle=.
#+begin_src emacs-lisp :tangle init.el
(setq org-babel-python-command
@@ -45,6 +51,27 @@ document, simply =M-x org-babel-tangle=.
;; R
* Loading files:
