cf4ff9be
cf4ff9be
htmlize
651ba73d
7 additions
+7
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+7
cf4ff9be
@@ -97,6 +97,13 @@ versions:
- Emacs 26.1
- Emacs 26.1
- Org-mode 9.1.13
- Org-mode 9.1.13
- ESS 17.11
- ESS 17.11
To have code pretty printing when exporting to html, it appears like
you should install the =htmlize= package, which is done by opening emacs
and typing the following command:
#+BEGIN_EXAMPLE
M-x package-install RET htmlize RET # where M-x means pressing the "Esc" key then the "x" key
#+END_EXAMPLE
*** Directory naming conventions
In all the following instructions, it is common to refer to your home
directory through the (UNIX) =~/= notation. On Windows, your home
