Update exercice_python_fr.org
parent 29f77a17
#+TITLE: Votre titre #+TITLE: Votre titre
#+AUTHOR: Votre nom
#+DATE: La date du jour
#+LANGUAGE: fr #+LANGUAGE: fr
# #+PROPERTY: header-args :eval never-export # #+PROPERTY: header-args :eval never-export
...@@ -11,83 +9,43 @@ ...@@ -11,83 +9,43 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Quelques explications #+begin_src python :results output :exports both :session
Ceci est un document org-mode avec quelques exemples de code values = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
document.
print("Hello world!")
#+end_src #+end_src
#+RESULTS: #+RESULTS:
: Hello world! : [14. 7.6 11.2 12.8 12.5 9.9 14.9 9.4 16.9 10.2 14.9 18.1 7.3 9.8
: 10.9 12.2 9.9 2.9 2.8 15.4 15.7 9.7 13.1 13.2 12.3 11.7 16. 12.4
: 17.9 12.2 16.2 18.7 8.9 11.9 12.1 14.6 12.1 4.7 3.9 16.9 16.8 11.3
: 14.4 15.7 14. 13.6 18. 13.6 19.9 13.7 17. 20.5 9.9 12.5 13.2 16.1
: 13.5 6.3 6.4 17.6 19.1 12.8 15.5 16.3 15.2 14.6 19.1 14.4 21.4 15.1
: 19.6 21.7 11.3 15. 14.3 16.8 14. 6.8 8.2 19.9 20.4 14.6 16.4 18.7
: 16.8 15.8 20.4 15.8 22.4 16.2 20.3 23.4 12.1 15.5 15.4 18.4 15.7 10.2
: 8.9 21. ]
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
Et enfin, voici un exemple de sortie graphique: #+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
plt.figure(figsize=(10,5)) plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x) plt.plot(values)
plt.tight_layout() plt.tight_layout()
plt.savefig(matplot_lib_filename) plt.savefig(matplot_lib_filename)
print(matplot_lib_filename) matplot_lib_filename
#+end_src #+end_src
[[file:./cosxsx.png]] [[file:/tmp/babel-kndLCL/figurero9XR0.png]]
Vous remarquerez le paramètre ~:exports results~ qui indique que le code plt.figure(figsize=(10,5))
ne doit pas apparaître dans la version finale du document. Nous vous plt.hist(values)
recommandons dans le cadre de ce MOOC de ne pas changer ce paramètre plt.tight_layout()
compréhensible sur GitLab.
Enfin, n'oubliez pas que nous vous fournissons dans les ressources de plt.savefig(matplot_lib_filename)
ce MOOC une configuration avec un certain nombre de raccourcis matplot_lib_filename
claviers permettant de créer rapidement les blocs de code python (en #+end_src
Maintenant, à vous de jouer! Vous pouvez effacer toutes ces #+RESULTS:
informations et les remplacer par votre document computationnel. [[file:/tmp/babel-kndLCL/figureoIbPwN.png]]
