Commit a13cd89b authored by Konrad Hinsen's avatar Konrad Hinsen
Module 2/exo 2: mise à jour et version anglaise
parent 2239ad4c
#+TITLE: Your title
#+AUTHOR: Your name
#+DATE: Today's date
#+LANGUAGE: en
* Some explanations
https://orgmode.org/guide/.
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
print("Hello world!")
: [1] "Hello world!"
And now the same but in an R session. This is the most frequent
situation, because R is really an interactive language. With a
session, R's state, i.e. the values of all the variables, remains
persistent from one code block to the next. The code is still executed
using ~C-c C-c~.
: speed dist
: Min. : 4.0 Min. : 2.00
: 1st Qu.:12.0 1st Qu.: 26.00
: Median :15.0 Median : 36.00
: Mean :15.4 Mean : 42.98
: 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00
plot(cars)
[[file:./cars.png]]
transparent and reproducible.
the org document. It's a plain file, here named ~cars.png~. You have
understandable on GitLab.
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
...@@ -3,7 +3,6 @@ ...@@ -3,7 +3,6 @@
#+DATE: La date du jour #+DATE: La date du jour
#+LANGUAGE: fr #+LANGUAGE: fr
# #+PROPERTY: header-args :eval never-export # #+PROPERTY: header-args :eval never-export
# #### :session :exports both
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
...@@ -36,7 +35,7 @@ print("Hello world!") ...@@ -36,7 +35,7 @@ print("Hello world!")
#+RESULTS: #+RESULTS:
: [1] "Hello world!" : [1] "Hello world!"
Voici la même chose, mais avec une session python (c'est le cas le Voici la même chose, mais avec une session R (c'est le cas le
plus courant, R étant vraiment un langage interactif), donc une plus courant, R étant vraiment un langage interactif), donc une
persistance d'un bloc à l'autre (et on l'exécute toujours en faisant persistance d'un bloc à l'autre (et on l'exécute toujours en faisant
~C-c C-c~). ~C-c C-c~).
...@@ -78,9 +77,8 @@ forcément de fichier de départ, ça sera à vous de le créer, par ...@@ -78,9 +77,8 @@ forcément de fichier de départ, ça sera à vous de le créer, par
exemple en repartant de ce document et de le commiter vers exemple en repartant de ce document et de le commiter vers
gitlab. N'oubliez pas que nous vous fournissons dans les ressources de gitlab. N'oubliez pas que nous vous fournissons dans les ressources de
ce MOOC une configuration avec un certain nombre de raccourcis ce MOOC une configuration avec un certain nombre de raccourcis
claviers permettant de créer rapidement les blocs de code python (en claviers permettant de créer rapidement les blocs de code R (en
faisant ~<r~ ou ~<R~ suivi de ~Tab~). faisant ~<r~ ou ~<R~ suivi de ~Tab~).
Maintenant, à vous de jouer! Vous pouvez effacer toutes ces Maintenant, à vous de jouer! Vous pouvez effacer toutes ces
informations pour essayer de reproduire le document sur le calcul de informations et les remplacer par votre document computationnel.
$\pi$.
title: "Your title"
author: "Your name"
date: "Today's date"
output: html_document
```{r setup, include=FALSE}
## Some explanations
```{r pressure, echo=FALSE}
plot(pressure)
...@@ -29,6 +29,5 @@ plot(pressure) ...@@ -29,6 +29,5 @@ plot(pressure)
Vous remarquerez le paramètre `echo = FALSE` qui indique que le code ne doit pas apparaître dans la version finale du document. Nous vous recommandons dans le cadre de ce MOOC de ne pas utiliser ce paramètre car l'objectif est que vos analyses de données soient parfaitement transparentes pour être reproductibles. Vous remarquerez le paramètre `echo = FALSE` qui indique que le code ne doit pas apparaître dans la version finale du document. Nous vous recommandons dans le cadre de ce MOOC de ne pas utiliser ce paramètre car l'objectif est que vos analyses de données soient parfaitement transparentes pour être reproductibles.
Comme les résultats ne sont pas stockés dans les fichiers Rmd, pour faciliter la relecture de vos analyses par d'autres personnes, vous aurez donc intérêt à générer un HTML ou un PDF et à le commiter. Comme les résultats ne sont pas stockés dans les fichiers Rmd, pour faciliter la relecture de vos analyses par d'autres personnes, vous aurez donc intérêt à générer un HTML ou un PDF et à le commiter.
Enfin, pour les prochains exercices, nous ne vous fournirons pas forcément de fichier de départ, ça sera à vous de le créer à partir de Rstudio et de le commiter vers gitlab.
Maintenant, à vous de jouer! Vous pouvez effacer toutes ces informations pour essayer de reproduire le document sur le calcul de $\pi$. Maintenant, à vous de jouer! Vous pouvez effacer toutes ces informations et les remplacer par votre document computationnel.
"cells": [],
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"nbformat": 4,
"nbformat_minor": 2
#+TITLE: Your title
#+AUTHOR: Your name
#+LANGUAGE: en
* Some explanations
: Hello world!
C-c~.
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
followed by ~Tab~.
...@@ -85,14 +84,10 @@ org. C'est un fichier ordinaire, ici nommé ~cosxsx.png~. N'oubliez pas ...@@ -85,14 +84,10 @@ org. C'est un fichier ordinaire, ici nommé ~cosxsx.png~. N'oubliez pas
de le committer si vous voulez que votre analyse soit lisible et de le committer si vous voulez que votre analyse soit lisible et
compréhensible sur GitLab. compréhensible sur GitLab.
Enfin, pour les prochains exercices, nous ne vous fournirons pas Enfin, n'oubliez pas que nous vous fournissons dans les ressources de
claviers permettant de créer rapidement les blocs de code python (en claviers permettant de créer rapidement les blocs de code python (en
faisant ~<p~, ~<P~ ou ~<PP~ suivi de ~Tab~). faisant ~<p~, ~<P~ ou ~<PP~ suivi de ~Tab~).
$\pi$.
