Commit dcf91d07 authored by Konrad Hinsen's avatar Konrad Hinsen
Nouvelles instructions pour Emacs sous macOS
parent 8f849ef1
...@@ -77,38 +77,12 @@ which is now deprecated. ...@@ -77,38 +77,12 @@ which is now deprecated.
** macOS ** macOS
*Note:* macOS comes with a prehistoric command-line-only version of Emacs located at =/usr/bin/emacs=. It's best to forget about it. *Note:* macOS comes with a prehistoric command-line-only version of Emacs located at =/usr/bin/emacs=. It's best to forget about it.
- *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: The Web site https://emacsformacosx.com/ proposes precompiled Emacs versions for macOS. Download the latest version (the one that figures prominently on the page) and install it like you would install any other macOS application, by copying =Emacs.app= from the downloaded disk image to a convenient location on your computer.
[[https://vigou3.gitlab.io/emacs-modified-macos/][https://vigou3.gitlab.io/emacs-modified-macos/]]. It ships with recent
versions: This Emacs version contains everything used in the MOOC except the packages [[https://ess.r-project.org/][ESS]] (for working with the R language) and [[https://www.gnu.org/software/auctex/][AUCTeX]] (for editing LaTeX). If you use the configuration described under [[#a-simple-reproducible-research-emacs-configuration][A simple "reproducible research" emacs configuration]], these packages will be installed automatically the first time you start Emacs.
- Emacs 26.1
- Org-mode 9.1.13 In case you need to run Emacs from the command line (note: this is not required in the MOOC), you have to enter the full path to the executable. Assuming that you have copied =Emacs.app= to =/path/to/emacs=, this is =/path/to/emacs/Emacs.app/Contents/MacOS/Emacs=. Note that if you just type =emacs=, you will use the prehistoric command-line-only version at =/usr/bin/emacs= provided by Apple.
- ESS 17.11
If you install this version of Emacs, or in fact any other version of
Emacs distributed as a clickable application in a =.dmg= file,
you must type the full path to the executable if you want to run
Emacs from a terminal. For example, if your clickable application
is at =/Applications/Emacs.app=, then the executable is at
=/Applications/Emacs.app/Contents/MacOS/Emacs=
- *Option 2*: If you use [[https://docs.brew.sh/][Homebrew]], do the following:
#+begin_src sh :results output :exports both
brew update
brew install emacs --with-cocoa
brew linkapps emacs
brew install wget
brew tap dunn/emacs
brew install auctex
brew tap brewsci/science
brew install ess
This provides an =emacs= command for use from the command line, plus a clickable application at =Cellar/emacs/26.1_1/Emacs.app= inside your Homebrew directory. If
you installed Homebrew at the default location =/usr/local=, then this is =/usr/local/Cellar/emacs/26.1_1/Emacs.app=.
If you installed Homebrew on an account with administrator privileges, you can add
brew linkapps emacs
in order to make Emacs accessible directly from =/Applications=.
** Windows ** Windows
Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]: Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]:
[[https://vigou3.gitlab.io/emacs-modified-windows/][https://vigou3.gitlab.io/emacs-modified-windows/]]. It ships with recent [[https://vigou3.gitlab.io/emacs-modified-windows/][https://vigou3.gitlab.io/emacs-modified-windows/]]. It ships with recent
** macOS ** macOS
- Emacs 26.1
- ESS 17.11
brew update
brew linkapps emacs
brew install wget
brew tap dunn/emacs
brew install auctex
brew install ess
brew linkapps emacs
...@@ -53,6 +53,25 @@ ...@@ -53,6 +53,25 @@
(package-initialize) (package-initialize)
(add-to-list 'package-archives (add-to-list 'package-archives
'("melpa-stable" . "http://stable.melpa.org/packages/")) '("melpa-stable" . "http://stable.melpa.org/packages/"))
'("melpa" . "http://melpa.org/packages/"))
(package-refresh-contents)
(setq package-archive-priorities '(("gnu" . 100)
("melpa-stable" . 10)))
(when (equal system-type 'darwin)
(unless (package-installed-p 'exec-path-from-shell)
(package-install 'exec-path-from-shell)))
(unless (package-installed-p 'ess)
(package-install 'ess))
(unless (package-installed-p 'auctex)
(package-install 'auctex))
(exec-path-from-shell-initialize)
(exec-path-from-shell-copy-env "PYTHONPATH"))
(require 'org) (require 'org)
...@@ -75,12 +75,40 @@ document, simply =M-x org-babel-tangle=. ...@@ -75,12 +75,40 @@ document, simply =M-x org-babel-tangle=.
#+end_src #+end_src
* Package sources * Package sources
** Use melpa-stable ** Use melpa-stable (preferred) and melpa
#+BEGIN_SRC emacs-lisp :tangle init.el #+BEGIN_SRC emacs-lisp :tangle init.el
#+END_SRC #+END_SRC
* Install missing packages
** For macOS:
#+begin_src emacs-lisp
** ESS
** AucTeX
* Import environment variables (macOS)
* Loading files: * Loading files:
** Loading babel: :ARNAUD: ** Loading babel: :ARNAUD:
#+begin_src emacs-lisp :tangle init.el #+begin_src emacs-lisp :tangle init.el
