Commit 9afb08dc authored by Jade Bolaty's avatar Jade Bolaty
résultats exo2 orgmode python
parent 94c1a750
...@@ -11,83 +11,18 @@ ...@@ -11,83 +11,18 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Quelques explications
document.
print("Hello world!")
: Hello world!
~C-c C-c~).
#+begin_src python :results output :session :exports both #+begin_src python :results output :session :exports both
import numpy import numpy as np
x=numpy.linspace(-15,15)
print(x)
#+RESULTS: mylist = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
plt.figure(figsize=(10,5)) print(np.mean(mylist))
plt.plot(x,numpy.cos(x)/x) print(np.min(mylist))
plt.tight_layout() print(np.max(mylist))
print(np.median(mylist))
plt.savefig(matplot_lib_filename) print(np.std(mylist,ddof=1))
#+end_src #+end_src
#+RESULTS: #+RESULTS:
[[file:./cosxsx.png]] : 14.113000000000001
compréhensible sur GitLab.
