a47dfd14a7f01006f3c7ad4954edbc21
c5ab9f7a
c5ab9f7a
Delete exercice_python_en.org
085f3002
0 additions
94 deletions
+0
-94
module3/exo3/exercice_python_en.org
+0
-94
deleted
100644 → 0
085f3002
#+TITLE: Your title
#+AUTHOR: Your name
#+DATE: Today's date
#+LANGUAGE: en
* Some explanations
https://orgmode.org/guide/.
print("Hello world!")
: Hello world!
C-c~.
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
