no commit message
parent fae686d0
......@@ -6,7 +6,53 @@
"module2/exo1/toy_notebook_en.ipynbWarning\n"
"# On the computation of $\\pi$\n",
"## Asking the maths library\n",
"My computer tells me that $\\pi$ is *approximatively*\n",
"from math import *\n",
"print(pi)\n",
"## Buffon's needle\n",
"Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__\n",
" \n",
"import numpy as np\n",
"np.random.seed(seed=42)\n",
"N = 10000\n",
"2/(sum((x+np.sin(theta))>1)/N)\n"
"execution_count": null,
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:\n",
" \n",
"%matplotlib inline \n",
"N = 1000\n",
"accept = (x*x+y*y) <= 1\n",
"ax.set_aspect('equal')\n",
"It is then straightforward to obtain a (not really good) approximation to $\\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:\n",
"4*np.mean(accept)"
