Commits (13)
# Journal de bord du Mooc / Mooc's logbook
## Module 1:
**Exercise 01-1:**
*Which two files contain the character string "LE MOOC RECHERCHE REPRODUCTIBLE C'EST GENIAL" ?*
module1/exo1/aebef6b0a5.txt
module1/exo1/f683bbad4b.txt
**Quiz 01**
*Why has a European project recently used the logbooks of the Portuguese, Spanish, Dutch and English Indian Companies*
To try to reconstitute the ocean climate criss-crossed by the Western navies
*What note media are illustrated in the course video "Note-taking concerns everyone" by Christophe Pouzat?*
- Notes in books and manuscripts margins
- Notes in field books
- Notes on cards and paper slips
*Why did Leibniz order the construction of a closet ?*
To store and order notes written on paper slips
*For the curious, visit the Darwin Online web sites go to the notebooks and describe how Darwin took his notes.*
First in notebooks then on cards and paper sheets stored in folders
**Quiz 02**
*What is the origin of the codex?*
The Egyptian production of papyrus was not large enough to meet the demand of writers
*What aspect of Eusebius work is presented in this sequence?*
His canon tables (cross-references between the Gospel books)
*In which line should the keyword "Analysis" go in John Locke's index ?*
« Aa »
**Quiz 03**
**Quiz 04**
**Quiz 05**
## Module 2
### toy project
# Asking the maths library
My computer tells me that π is approximatively
```python
from math import *
print(pi)
3.141592653589793
# Buffon’s needle
Applying the method of Buffon’s needle, we get the approximation
```python
np.random.seed(seed=42)
N = 10000
2/(sum((x+np.sin(theta))>1)/N)
3.128911138923655
# Using a surface fraction argument
A method that is easier to understand and does not make use of the sin function is based on the
fact that if X ∼ U(0, 1) and Y ∼ U(0, 1), then P[X
2 + Y
2 ≤ 1] = π/4 (see "Monte Carlo method"
on Wikipedia). The following code uses this approach:
```python
%matplotlib inline
N = 1000
accept = (x*x+y*y) <= 1
fig, ax = plt.subplots(1)
ax.set_aspect('equal')
It is then straightforward to obtain a (not really good) approximation to π by counting how
many times, on average, X
2 + Y
2
is smaller than 1:
```python
4*np.mean(accept)
3.112
```python
**Exercice 02-2**
*What is the average ?*
14.11
*What is the minimum ?*
2.8
*What is the maximum ?*
23.4
*What is the median ?*
14.5
*What is the standard deviation ?*
4.33
**Quiz 06**
*A computational document allows you to:*
- Improve the traceability of a calculation
- Easily present your work to colleagues
- Access all the calculations underlying an analysis
*Which environment(s) are presented to you in this MOOC?*
- Rstudio
- Emacs/OrgMode
- Jupyter
*Which environment is recommended if your preferred language is Python?*
Jupyter
*Which environment is recommended if your preferred language is the R language?*
Rstudio
*RstudioWhich environment is used daily by the three authors of this MOOC?*
Emacs/OrgMode b. Emacs/OrgMode - correct
**Quiz 7**
*In the studies we have presented to you, what prevents, sometimes for several years, the debate on the relevance of a study?*
- Unpublished computation procedures
- Data used in the study was not released
*In the various examples presented (economics, MRI, crystallography), what are the main causes of errors ?*
- Data acquisition (bias, machine calibration, etc.)
- Computation errors
- Inadequate data processing or statistics
*What are the consequences of lack of transparency?*
- It's difficult to rely on the work of others
- Articles contain less information (no details on calculations, experimental protocols, data analysis, etc.) and are therefore easier to read
- It is difficult to verify and reproduce the analyses presented in the articles
- Two articles may present results that seem to contradict each other, but are both perfectly correct, as the lack of detail prevents the exact conditions of application from being determined
**Quiz 8**
*What are the main technical causes behind the difficulties in reproducing someone else's work?*
- Lack of documentation on the choices made
- Interactive graphical software that hide computation details
- Data loss (no backup or no more readable format)
*Which solutions are mentioned?*
- Using a laboratory notebook
- Code review and continuous integration
- Using version control systems and several backup mechanisms
*What are the most legitimate/valid fears associated with the systematic disclosure of data (open data)*
- Some information may be sensitive and its disclosure may hurt people
- My resources are limited. If I systematically host all this data on the web page provided by my employer, I am likely to quickly exceed my quota
FR
Espace réservé au journal de bord du Mooc
EN
Reserved for the Mooc's logbook
\ No newline at end of file
Module 1
# Module 1
## Note in this log book:
1. what you learn in this MOOC, references that you consider useful, etc.
2. daily data that is of interest to you, e.g. the time you spend on this MOOC. You will make use of it in module 2.
test
# Partie 1
## Sous-partie 1 : texte
Une phrase sans rien
_Une phrase en italique_
__Une phrase en gras__
Un lien vers fun-mooc.fr
Une ligne de code
## Sous-partie 2 : listes
__Liste à puce__
- item
- sous-item
- sous-item
- item
- item
__Liste numérotée__
1. item
2. item
3. item
## Sous-partie 3 : code
```# Extrait de code```
This diff is collapsed.
