victormg
02c8c89c
02c8c89c
victormg
Adding tags labels and search engines
db305365
29 additions
+29
Readme.md
journal/Readme.md
+29
journal/Readme.md
02c8c89c
@@ -37,3 +37,32 @@ CALCULATIONS:
For each new keyword falling in the same index entry, the subsequent page numbers must
be separated by some punctuation mark, ike the usual virgule.
## Tags, labels and search engines
The same way we do with latex to reference floating objects, we can create labels inside
files to highlight some specific information contained inside it. Inside files containing
code, for example, one could put labels inside commentaries. Let's take an example where a
FORTRAN .f90 file contains a FFT subroutine which we want to label for future use. We could
then do:
fortran
! FAST FOURIER TRANSFORM :FFT
where we put the label :FFT. One can choose any label, they only rule is to follow
logic and be organized, do not just create random label forms each time labelling is needed.
The above logic can also be applied to metadata (image files) by adding specific fields
in the file header.
Now, to search these labels inside files we need an appropriate engine. Inside linux, the easiest way
is to
`grep`
`pdfgrep`
expression. During the course the following desktop applications were suggested:
DocFetcher
http://docfetcher.sourceforge.net/en/index.html
Recoll
https://www.lesbonscomptes.com/recoll/
Tracker
https://wiki.gnome.org/Projects/Tracker
for files containing text and metadata. For images,
Imagemagick
https://imagemagick.org/script/index.php
Exiftoll
https://exiftool.org/
can also be employed.
