victormg
33786a46
33786a46
Victor-M-Gomes
Commit exo2 and exo3 module2
88c909bb
7
7 changed files
79 additions
134 deletions
+79
-134
module2/exo1/cars.png
+0
module2/exo1/cosxsx.png
+0
exercice_python_en.org
module2/exo2/exercice_python_en.org
+37
-69
module2/exo3/exercice_python_en.org
+42
-65
module2/exo3/figure_pi_mc2.png
+0
module2/exo3/matplot_lib_filename.png
+0
module2/exo3/matplot_lib_hist.png
+0
deleted
100644 → 0
88c909bb
6.53 KB
deleted
100644 → 0
88c909bb
31.4 KB
33786a46
#+TITLE:
Your title
#+AUTHOR:
Your name
#+DATE:
Today's date
#+TITLE:
Doing a simple calculation on your own
#+AUTHOR:
Victor Martins Gomes
#+DATE:
2020-04-28 tuesday
#+LANGUAGE: en
# #+PROPERTY: header-args :
eval never-export
session :exports both
@@ -11,84 +11,52 @@
* Some explanations
* Computing statistics of series:
The mean, standard variation, median, maximum and minimum of the following series are going to be computed.
https://orgmode.org/guide/.
print("Hello world!")
** First we input the series.
x=[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
print(x)
: Hello world!
C-c~.
: [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
import numpy
x=numpy.linspace(-15,15
print(x)
** Computing the mean
avg_x = np.mean(x
print(
avg_
x)
: 14.113000000000001
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
** Computing the median
med_x = np.median(x)
print(med_x)
[[file:./cosxsx.png]]
: 14.5
transparent and reproducible.
** Computing the standard deviation
std_x = np.std(x,ddof=1)
print(std_x)
understandable on GitLab.
: 4.334094455301447
followed by ~Tab~.
** Computing min and max
min_x = np.amin(x)
max_x = np.amax(x)
print('Min and Max are:',min_x,'and',max_x)
: Min and Max are: 2.8 and 23.4
33786a46
#+TITLE: Your title
#+AUTHOR:
Your name
#+DATE:
Today's date
#+AUTHOR:
#+DATE:
2020-04-28 Tuesday.
#+LANGUAGE: en
@@ -11,84 +11,61 @@
* Some explanations
* Data visualization
Making plots of data.
** First we input the series/data.
print(x)
** Now we plot the series
#+begin_src python :results output file :var matplot_lib_filename="matplot_lib_filename.png" :exports both :session *python*
plt.figure()
plt.plot(x,'b')
plt.grid(linestyle='dotted')
plt.axis('tight')
plt.xlim( 0,100 )
plt.ylim( 0,25 )
plt.title('Plotting series')
: Hello world!
C-c~.
[[file:matplot_lib_filename.png]]
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.close('all')
[[file:]]
** Now the histogram
#+begin_src python :results output file :var matplot_lib_filename="matplot_lib_hist.png" :exports both :session *python*
plt.tight_layout()
plt.figure()
plt.hist(x,color='b',histtype='bar',ec='black')
plt.axis('tight')
plt.xlim( 0,25 )
plt.ylim( 0,25 )
plt.title('Histogram series')
followed by ~Tab~.
[[file:matplot_lib_hist.png]]
module2/exo
1/matplot_lib_filename
.png
module2/exo
3/figure_pi_mc2
.png
33786a46
File moved
33786a46
43.4 KB
33786a46
24.1 KB
