Update toy_document_en.Rmd
parent 00d16c82
......@@ -5,7 +5,6 @@ date: "25 juin 2018"
output: html_document
```{r setup, include=FALSE}
......@@ -29,7 +28,7 @@ theta = pi/2*runif(N)
## Using a surface fraction argument
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see [“Monte Carlo method” on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\leq 1] = \pi/4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
set.seed(42)
......@@ -38,9 +37,12 @@ df = data.frame(X = runif(N), Y = runif(N))
library(ggplot2)
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1 :
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1:
4*mean(df$Accept)
\ No newline at end of file
