af867c30e46f4b444ec768838323b91d
cefc480f
cefc480f
Update toy_document_orgmode_R_en.org
b9245625
6 additions
68 deletions
+6
-68
module2/exo1/toy_document_orgmode_R_en.org
+6
-68
cefc480f
#+TITLE: Your title
#+TITLE: On the computation of pi
#+AUTHOR: Your name
#+DATE: Today's date
#+LANGUAGE: en
#+LANGUAGE: en
@@ -11,71 +9,11 @@
@@ -11,71 +9,11 @@
* Some explanations
#+PROPERTY: header-args :session :exports both
https://orgmode.org/guide/.
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
* Asking the maths library
print("Hello world!")
My computer tells me that $\pi$ is /approximatively/
: [1] "Hello world!"
And now the same but in an R session. This is the most frequent
situation, because R is really an interactive language. With a
session, R's state, i.e. the values of all the variables, remains
persistent from one code block to the next. The code is still executed
using ~C-c C-c~.
pi
: speed dist
: Min. : 4.0 Min. : 2.00
: 1st Qu.:12.0 1st Qu.: 26.00
: Median :15.0 Median : 36.00
: Mean :15.4 Mean : 42.98
: 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00
plot(cars)
[[file:./cars.png]]
transparent and reproducible.
the org document. It's a plain file, here named ~cars.png~. You have
understandable on GitLab.
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
