* Reproduce the first figure (sequence plot)
```{r pressure, echo=FALSE}
plot(data_set,
plot(pressure)
type = "l", # "l" for line plot (use "p" for points, "b" for both)
main = "Values of Data Set Over Index", # Title of the plot
xlab = "Index", # Label for the x-axis
ylab = "Value", # Label for the y-axis
col = "blue", # Color of the line
lwd = 2 # Line width
[[file:./plot.png]]
