Commit 7534886d authored by Herve Pabiou's avatar Herve Pabiou
2e correction de l'exercice
parent 90a82c70
#+TITLE: À propos du calcul de $\pi$ #+TITLE: À propos du calcul de $\pi$
#+LANGUAGE: fr #+LANGUAGE: fr
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/> #+LANGUAGE: fr #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/> # #+PROPERTY: header-args :eval never-export #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
#+HTML_HEAD: <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script> #+HTML_HEAD: <script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
#+HTML_HEAD: <script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/js/bootstrap.min.js"></script> #+HTML_HEAD: <script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/js/bootstrap.min.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
#+PROPERTY: header-args :eval never-export #+PROPERTY: header-args :session :exports both
* En demandant à la lib maths * En demandant à la lib maths
Mon ordinateur m'indique que $\pi$ vaut /approximativement/ Mon ordinateur m'indique que $\pi$ vaut /approximativement/:
#+begin_src python :results value :session *python* :exports both #+begin_src python :results value :session *python* :exports both
from math import * from math import *
...@@ -27,8 +27,8 @@ pi ...@@ -27,8 +27,8 @@ pi
* En utilisant la méthode des aiguilles de Buffon * En utilisant la méthode des aiguilles de Buffon
Mais calculé avec la *méthode* des Mais calculé avec la *méthode* des
[[https://fr.wikipedia.org/wiki/Aiguille_de_Buffon][aiguilles de Buffon]], on [[https://fr.wikipedia.org/wiki/Aiguille_de_Buffon][aiguilles de Buffon]], on obtiendrait
obtiendrait comme *approximation* : comme *approximation* :
import numpy as np import numpy as np
...@@ -46,10 +46,11 @@ theta = np.random.uniform(size=N, low=0, high=pi/2) ...@@ -46,10 +46,11 @@ theta = np.random.uniform(size=N, low=0, high=pi/2)
* Avec un argument "fréquentiel" de surface * Avec un argument "fréquentiel" de surface
Sinon, une méthode plus simple à comprendre et ne faisant pas Sinon, une méthode plus simple à comprendre et ne faisant pas
intervenir d'appel à la fonction sinus se base sur le fait que si $X \sim U(0,1)$ et $Y \sim U(0,1)$ alors $P[X² + Y²\le1]=\pi/4$ (voir [[https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80][méthode de Monte Carlo sur Wikipedia]]). intervenir d'appel à la fonction sinus se base sur le fait que si $X \sim
U(0,1)$ et $Y \sim U(0,1)$ alors $P[X^2 + Y²\le1] = \pi/4$ (voir [[https://fr.wikipedia.org/wiki/M%C3%A9thode_de_Monte-Carlo#D%C3%A9termination_de_la_valeur_de_%CF%80][méthode de Monte Carlo sur Wikipedia]]).
Le code suivant illustre ce fait : Le code suivant illustre ce fait :
#+begin_src python :results output file :var matplot_lib_filename="figure_pi_mc2.png" :exports both :session *python* #+begin_src python :results output file :var matplot_lib_filename="figure_pi_mc2.png" :exports both :session *python*
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
np.random.seed(seed=42) np.random.seed(seed=42)
...@@ -71,14 +72,12 @@ print(matplot_lib_filename) ...@@ -71,14 +72,12 @@ print(matplot_lib_filename)
#+RESULTS: #+RESULTS:
[[file:figure_pi_mc2.png]] [[file:figure_pi_mc2.png]]
Il est alors aisé d'obtenir une approximation (pas terrible) de $π$ Il est alors aisé d'obtenir une approximation (pas terrible) de $π$
en comptant combien de fois, en moyenne, $X²+Y²$ est inférieur à 1 : en comptant combien de fois, en moyenne, $X²+Y²$ est inférieur à 1 :
#+begin_src python :results output :session :exports both #+begin_src python :results output :session *python* :exports both
4*np.mean(accept) 4*np.mean(accept)
print(4*np.mean(accept))
#+end_src #+end_src
