c4e0d8d31afd537cd0fb8604ea8660c1
5d5c333b
5d5c333b
Exercice
4595da27
159 additions
3 deletions
+159
-3
exercice.ipynb
module2/exo2/exercice.ipynb
+159
-3
5d5c333b
"cells": [],
"cells": [
"# Exercice - Le document computationnel : Savoir faire un calcul soi-même"
"## Calculons la moyenne, le minimum, la médiane et le maximum du vecteur $X$ suivant : "
"execution_count": 4,
"import numpy as np \n",
"X = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"## Calcul de la moyenne de $X$, $\\overline{X}$ : "
"execution_count": 7,
"14.113000000000001\n"
"Xmoy = np.mean(X)\n",
"print(Xmoy)"
"## Calcul du minimum de $X$, $X_\\mathrm{min}$ :"
"execution_count": 9,
"2.8\n"
"Xmin = np.min(X)\n",
"print(Xmin)"
"## Calcul du minimum de $X$, $X_\\mathrm{max}$ :"
"execution_count": 10,
"23.4\n"
"Xmax = np.max(X)\n",
"print(Xmax)"
"## Calcul de la médiane de $X$, $X_\\mathrm{med}$ :"
"execution_count": 13,
"2.899\n"
"Xmed = np.percentile(X,1)\n",
"print(Xmed)"
"## Calcul de l'écart type, $\\sigma_X$ :"
"execution_count": 14,
"4.312369534258399\n"
"stdX = np.std(X)\n",
"print(stdX)"
"execution_count": null,
"source": []
"kernelspec": {
"kernelspec": {
"display_name": "Python 3",
@@ -16,10 +173,9 @@
@@ -16,10 +173,9 @@
"name": "python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.
3
"version": "3.6.
4
"nbformat": 4,
"nbformat": 4,
"nbformat_minor": 2
"nbformat_minor": 2
