cbf2a0f1c424a082bc63da14e09521bb
c69eec86
c69eec86
Christophe Durand
Ajout de l'exercice 2
4fc3d5fb
2
2 changed files
72 additions
71 deletions
+72
-71
exercice_python_fr.org
module2/exo2/exercice_python_fr.org
+72
-71
module2/exo2/sequence_histogram.png
+0
c69eec86
#+TITLE:
Votre titre
#+TITLE:
Calculs de base python
#+AUTHOR:
Votre nom
#+AUTHOR:
Christophe Durand
#+DATE:
La date du jour
#+DATE:
30/05/2024
@@ -11,83 +11,84 @@
@@ -11,83 +11,84 @@
* Quelques explications
* Calculs de base
#+begin_src python :results output replace drawer :session :exports both
data= np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, \
14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, \
9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, \
9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, \
17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, \
11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, \
13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, \
14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, \
20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, \
15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0] )
#print(data)
print('Moyenne : ' + str(data.mean()))
print('Écart-type : ' + str(data.std(ddof=1)))
print('Minimum : ' + str(data.min()))
print('Maximum : ' + str(data.max()))
print('Médiane : ' + str(np.median(data)))
document.
print("Hello world!")
: Hello world!
:results:
Moyenne : 14.113000000000001
Écart-type : 4.334094455301447
Minimum : 2.8
~C-c C-c~).
Maximum : 23.4
Médiane : 14.5
import numpy
:end:
x=numpy.linspace(-15,15)
print(x)
* Quelques graphiques
#+begin_src python :results output file file drawer :session :exports both :var sequence_filename="./sequence.png" :var histogram_filename="./histogram.png" :var sequence_histogram_filename="./sequence_histogram.png"
plt.figure(figsize=(10,5))
fig_sequence=plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.plot(data)
plt.tight_layout()
plt.savefig(sequence_filename)
#print(sequence_filename)
plt.close(fig_sequence)
fig_histogram=plt.figure(figsize=(10,5))
plt.plot(data)
plt.tight_layout()
plt.tight_layout()
plt.savefig(histogram_filename)
#print(histogram_filename)
plt.close(fig_histogram)
fig_sequence_histogram=plt.figure(figsize=(10,5))
plt.subplot(2,1,1)
plt.plot(data)
plt.tight_layout()
plt.subplot(2,1,2)
#y=np.histogram(data, density=True)
plt.hist(data)
plt.savefig(sequence_histogram_filename)
plt.close(fig_sequence_histogram)
print(sequence_histogram_filename)
[[file:./cosxsx.png]]
:results:
[[file:./sequence_histogram.png]]
:end:
compréhensible sur GitLab.
c69eec86
43.9 KB
