exercices
parent 8cd9654a
......@@ -11,84 +11,35 @@
* Some explanations
https://orgmode.org/guide/.
print("Hello world!")
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
l= [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
print(len(l))
x=numpy.linspace(0,100,100)
plt.figure(figsize=(10,5))
plt.plot(x,l)
: Hello world!
C-c~.
[[file:/tmp/babel-XsHjUo/figure3nkNUU.png]]
import numpy
x=numpy.linspace(-15,15)
print(x)
#+begin_src python :results file :session :var matplot_lib_file=(org-babel-temp-file "figure2" ".png") :exports both
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
print(len(l))
num_bins = 10
n, bins, patches = plt.hist(l,num_bins, facecolor = 'blue', alpha = 0.5, edgecolor= 'black')
plt.savefig(matplot_lib_file)
matplot_lib_file
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
[[file:/tmp/babel-XsHjUo/figure2jJAtRy.png]]
......@@ -42,6 +42,7 @@ data
1 4/12/81 6 66 50 0
2 11/12/81 6 70 50 1
......@@ -104,7 +105,6 @@ plot(data=data, Malfunction/Count ~ Temperature, ylim=c(0,1))
[[file:freq_temp.png]]
À première vue, ce n'est pas flagrant mais bon, essayons quand même
d'estimer l'impact de la température $t$ sur la probabilité de
......@@ -134,21 +134,23 @@ glm(formula = Malfunction/Count ~ Temperature, family = binomial(link = "logit")
data = data, weights = Count)
Deviance Residuals:
2 9 10 11 14 21 23
-0.3015 -0.2836 -0.2919 -0.3015 0.6891 0.6560 -0.2850
Min 1Q Median 3Q Max
-0.95227 -0.78299 -0.54117 -0.04379 2.65152
Coefficients:
Estimate Std. Error z value Pr(>|z|)
(Intercept) -1.389528 3.195752 -0.435 0.664
Temperature 0.001416 0.049773 0.028 0.977
(Intercept) 5.08498 3.05247 1.666 0.0957 .
Temperature -0.11560 0.04702 -2.458 0.0140 *
codes: 0 ‘***’ 0.001 ‘**’ 0.01 ‘*’ 0.05 ‘.’ 0.1 ‘ ’ 1
(Dispersion parameter for binomial family taken to be 1)
Null deviance: 1.3347 on 6 degrees of freedom
Residual deviance: 1.3339 on 5 degrees of freedom
AIC: 18.894
Null deviance: 24.230 on 22 degrees of freedom
Residual deviance: 18.086 on 21 degrees of freedom
AIC: 35.647
Number of Fisher Scoring iterations: 4
Number of Fisher Scoring iterations: 5
L'estimateur le plus probable du paramètre de température est 0.001416
......@@ -80,6 +80,47 @@ Regardons ce que nous avons obtenu:
table[:5]
#+END_SRC
** Utilisation de données locales
Dans le cas ou internet est indisponible, ou si le jeu de données
fourni en ligne est susceptible d’être modifié, mieux vaut travailler
sur des données téléchargées, en local.
On vérifie que le jeu de données n’existe pas déja
#+begin_src shell :session *shell* :results output :exports both
cd /home/lcs/Documents/césure/mooc-rr/module3/exo1
ls
: analyse-syndrome-grippal.ipynb incidence-PAY-3.csv
: analyse-syndrome-grippal.org#' influenza-like-illness-analysis.ipynb
: analyse-syndrome-grippal.org influenza-like-illness-analysis.org
: analyse-syndrome-grippal.Rmd influenza-like-illness-analysis.Rmd
#+BEGIN_SRC python :results silent :var data_url=data-url
#import panda as pd
#data = pd.read_csv('incidence-PAY-3.csv',header = 1)
import csv
with open('incidence-PAY-3.csv') as csv_file:
csv_read=csv.reader(csv_file, delimiter=',')
lines = data.decode('latin-1').strip().split('\n')
data_lines = lines[1:]
table = [line.split(',') for line in data_lines]
#+END_SRC
#+BEGIN_SRC python :results value
table[:5]
#+END_SRC
** Recherche de données manquantes
Il y a malheureusement beaucoup de façon d'indiquer l'absence d'un point de données. Nous testons ici seulement pour la présence de champs vides. Il faudrait aussi rechercher des valeurs non-numériques dans les colonnes à priori numériques. Nous ne le faisons pas ici, mais une vérification ultérieure capterait des telles anomalies.
......@@ -94,6 +135,13 @@ for row in table:
valid_table.append(row)
#+END_SRC
: Traceback (most recent call last):
: File "<stdin>", line 1, in <module>
: File "/tmp/babel-XsHjUo/python-WeKugl", line 2, in <module>
: for row in table:
: NameError: name 'table' is not defined
** Extraction des colonnes utilisées
Il y a deux colonnes qui nous intéressent: la première (~"week"~) et la troisième (~"inc"~). Nous vérifions leurs noms dans l'en-tête, que nous effaçons par la suite. Enfin, nous créons un tableau avec les deux colonnes pour le traitement suivant.
