Commits (3)
#+TITLE: Your title #+TITLE: Fichier R exo module2
#+AUTHOR: Your name #+AUTHOR: Sylla
#+DATE: Today's date #+DATE: 24 4juin 2021
#+LANGUAGE: en #+LANGUAGE: en
# #+PROPERTY: header-args :eval never-export # #+PROPERTY: header-args :eval never-export
...@@ -11,27 +11,14 @@ ...@@ -11,27 +11,14 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Some explanations #+begin_src R :results output :session *R* :exports both
summary(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
This is an org-mode document with code examples in R. Once opened in #+RESULTS:
https://orgmode.org/guide/.
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
print("Hello world!")
: [1] "Hello world!" : [1] "Hello world!"
And now the same but in an R session. This is the most frequent And now the same but in an R session. This is the most frequent
...@@ -53,29 +40,4 @@ summary(cars) ...@@ -53,29 +40,4 @@ summary(cars)
: 3rd Qu.:19.0 3rd Qu.: 56.00 : 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00 : Max. :25.0 Max. :120.00
Finally, an example for graphical output: #
plot(cars)
[[file:./cars.png]]
transparent and reproducible.
the org document. It's a plain file, here named ~cars.png~. You have
understandable on GitLab.
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
...@@ -10,13 +10,8 @@ output: html_document ...@@ -10,13 +10,8 @@ output: html_document
## Quelques explications
```{r cars} ```{r cars}
cars<- (14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
summary(cars) summary(cars)
...@@ -26,8 +21,3 @@ Et on peut aussi aisément inclure des figures. Par exemple: ...@@ -26,8 +21,3 @@ Et on peut aussi aisément inclure des figures. Par exemple:
plot(pressure) plot(pressure)
