Ajout des commentaires
parent a8138c1b
"cells": [ "cells": [
"cell_type": "code", "cell_type": "markdown",
"execution_count": 1,
"source": [ "source": [
"import numpy as np" "## Création du jeu de données avec Numpy"
"execution_count": 2, "execution_count": 1,
"outputs": [], "outputs": [],
"import numpy as np\n",
"data = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8,\n", "data = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8,\n",
" 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1,\n", " 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1,\n",
" 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2,\n", " 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2,\n",
...@@ -23,9 +22,16 @@ ...@@ -23,9 +22,16 @@
" 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])" " 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])"
"## Recherche du minimum"
"execution_count": 3, "execution_count": 2,
"outputs": [ "outputs": [
...@@ -34,7 +40,7 @@ ...@@ -34,7 +40,7 @@
"2.8" "2.8"
"output_type": "execute_result" "output_type": "execute_result"
...@@ -43,9 +49,16 @@ ...@@ -43,9 +49,16 @@
"data.min()" "data.min()"
"## Recherche du maximum"
"execution_count": 5, "execution_count": 3,
...@@ -54,7 +67,7 @@ ...@@ -54,7 +67,7 @@
"23.4" "23.4"
...@@ -63,9 +76,16 @@ ...@@ -63,9 +76,16 @@
"data.max()" "data.max()"
"## Calcul de la valeur moyenne"
"execution_count": 6, "execution_count": 4,
...@@ -74,7 +94,7 @@ ...@@ -74,7 +94,7 @@
"14.113000000000001" "14.113000000000001"
...@@ -83,9 +103,16 @@ ...@@ -83,9 +103,16 @@
"data.mean()" "data.mean()"
"## Calcul de l'écart type"
"execution_count": 7, "execution_count": 5,
...@@ -94,7 +121,7 @@ ...@@ -94,7 +121,7 @@
"4.334094455301447" "4.334094455301447"
...@@ -103,9 +130,16 @@ ...@@ -103,9 +130,16 @@
"data.std(0, ddof=1)" "data.std(0, ddof=1)"
"## Calcul de la valeur médiane"
"execution_count": 10, "execution_count": 6,
...@@ -114,7 +148,7 @@ ...@@ -114,7 +148,7 @@
"14.5" "14.5"
