d69ce9ef7be042fe52e0604b1aeb453c
13f6b3f4
13f6b3f4
module 2-exercise 2 2nd part
8d9e5b93
3
3 changed files
130 additions
3 deletions
+130
-3
Untitled.ipynb
module2/exo2/Untitled.ipynb
+6
Untitled1.ipynb
module2/exo2/Untitled1.ipynb
+6
exercice.ipynb
module2/exo2/exercice.ipynb
+118
-3
13f6b3f4
"cells": [],
"nbformat": 4,
"nbformat_minor": 4
13f6b3f4
"cells": [],
"nbformat": 4,
"nbformat_minor": 4
13f6b3f4
"cells": [],
"cells": [
"execution_count": 2,
"the mean is 14.113000000000001\n"
"list=[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"import numpy as np\n",
"# Calculate the mean \n",
"print('the mean is', np.mean(list))"
"execution_count": 5,
"the standard deviation is 4.312369534258399\n"
"print('the standard deviation is', np.std(list))"
"execution_count": 6,
"the median is 14.5\n"
"print ('the median is ', np.median(list))"
"execution_count": 8,
"the minimum is 2.8\n"
"print('the minimum is', np.min(list))"
"execution_count": 9,
"the maximum is 23.4\n"
"print('the maximum is', np.max(list))"
"execution_count": 12,
"4.334094455301447"
"np.std((list), ddof=1)"
"execution_count": null,
"source": []
"kernelspec": {
"kernelspec": {
"display_name": "Python 3",
@@ -16,10 +132,9 @@
@@ -16,10 +132,9 @@
"name": "python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.
3
"version": "3.6.
4
"nbformat": 4,
"nbformat": 4,
"nbformat_minor": 2
"nbformat_minor": 2
