exo
parent 1e2e20d7
......@@ -4,30 +4,29 @@ author: "Votre nom"
date: "La date du jour"
output: html_document
```{r setup, include=FALSE}
## Quelques explications
l=c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
print('mean')
print(mean(l))
```{r pressure, echo=FALSE}
plot(pressure)
print('ecart type')
print(sd(l))
print('min')
print(min(l))
print('max')
print(max(l))
print('medialne')
print(median(l))
......@@ -4,30 +4,15 @@ author: "Votre nom"
plot(1:length(l),l,type = "l",col="blue",xlab=" ",ylab=" ",xlim =c(0,100))
hist(l,col="blue",xlab=" ",ylab=" ",xlim=c(0,25))
grid()
plot(pressure)
