"ajout de l'utilisation de la fonction 'describe()' : fonction qui affiche...
"ajout de l'utilisation de la fonction  'describe()' : fonction qui affiche les statistiques globales du tableau "
parent e1efba9f
......@@ -168,6 +168,122 @@
"print (\"valeur_mediane=\",np.median(tableau))"
"## Utilisation de la methode 'describe()' qui s'applique au type DataFrame :"
"execution_count": 2,
"# importer la librairie pour les fonctionnalites de type DataFrame\n",
"import pandas as pd"
"execution_count": 5,
"tableau=[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"#print (\"tableau=\",tableau)\n",
"df = pd.DataFrame(tableau)"
"execution_count": 6,
"text/html": [
"<div>\n",
"<style scoped>\n",
" vertical-align: middle;\n",
" }\n",
" vertical-align: top;\n",
" }\n",
" .dataframe thead th {\n",
" text-align: right;\n",
" }\n",
"</style>\n",
" <thead>\n",
" <th></th>\n",
" <th>0</th>\n",
" </tr>\n",
" </thead>\n",
" <tbody>\n",
" <tr>\n",
" <th>count</th>\n",
" <td>100.000000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>mean</th>\n",
" <td>14.113000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>std</th>\n",
" <td>4.334094</td>\n",
" </tr>\n",
" <tr>\n",
" <th>min</th>\n",
" <td>2.800000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>25%</th>\n",
" <td>11.850000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>50%</th>\n",
" <td>14.500000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>75%</th>\n",
" <td>16.800000</td>\n",
" </tr>\n",
" <tr>\n",
" <th>max</th>\n",
" <td>23.400000</td>\n",
" </tr>\n",
" </tbody>\n",
"</table>\n",
"</div>"
" 0\n",
"count 100.000000\n",
"mean 14.113000\n",
"std 4.334094\n",
"min 2.800000\n",
"25% 11.850000\n",
"50% 14.500000\n",
"75% 16.800000\n",
"max 23.400000"
"# Faire afficher les statistiques principales sur les données de ce tableau converti en DataFrame :\n",
"df.describe()"
"execution_count": null,
