no commit message
parent 3a3f2d24
"cells": [],
"cells": [
"execution_count": null,
"execution_count": 1,
"3.141592653589793\n"
"from math import *\n",
"print(pi)"
"Mais calculé avec la __méthode__ des [aiguilles de Buffon](https://fr.wikipedia.org/wiki/Aiguille_de_Buffon), on obtiendrait comme __approximation__ :\n"
"import numpy as np\n",
"np.random.seed(seed=42)\n",
"N = 10000\n",
"%matplotlib inline \n",
"N = 1000\n",
"accept = (x*x+y*y) <= 1\n",
"ax.set_aspect('equal')"
"4*np.mean(accept)"
"kernelspec": {
"display_name": "Python 3",
......@@ -16,10 +129,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
