Update exercice_en.Rmd
parent 35df87d2
title: "Your title" title: "Exo 3"
author: "Your name" author: "Palepro Del Alprogramation"
date: "Today's date" date: "08/02/2021r"
...@@ -10,24 +10,24 @@ output: html_document ...@@ -10,24 +10,24 @@ output: html_document
## Some explanations ```{r data}
vec_data <-
c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
This is an R Markdown document that you can easily export to HTML, PDF, and MS Word formats. For more information on R Markdown, see <http://rmarkdown.rstudio.com>. ```{r seq_plot}
data <- as.data.frame(cbind(vec_data,index = c(1:length(vec_data))))
```{r cars} ggplot(data, aes(x = index, y = vec_data))+
summary(cars) geom_line()+
theme_classic()
It is also straightforward to include figures. For example: ggplot(data, aes( x = vec_data))+
geom_histogram(bins=10)+
```{r pressure, echo=FALSE} theme_classic()
plot(pressure)
