ec11d4f067cc23c820aa71cb097f43d4
184d0c3b
184d0c3b
Update-1
f2d97547
34 additions
65 deletions
+34
-65
exercice_python_fr.org
module2/exo2/exercice_python_fr.org
+34
-65
184d0c3b
#+TITLE: Votre titre
#+TITLE: Exercice 02-2
#+AUTHOR: Votre nom
#+DATE: La date du jour
@@ -11,83 +9,54 @@
@@ -11,83 +9,54 @@
* Quelques explications
* Préparation des données
#+begin_src python :results value :session :exports both
a = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
a
document.
print("Hello world!")
: Hello world!
| 14.0 | 7.6 | 11.2 | 12.8 | 12.5 | 9.9 | 14.9 | 9.4 | 16.9 | 10.2 | 14.9 | 18.1 | 7.3 | 9.8 | 10.9 | 12.2 | 9.9 | 2.9 | 2.8 | 15.4 | 15.7 | 9.7 | 13.1 | 13.2 | 12.3 | 11.7 | 16.0 | 12.4 | 17.9 | 12.2 | 16.2 | 18.7 | 8.9 | 11.9 | 12.1 | 14.6 | 12.1 | 4.7 | 3.9 | 16.9 | 16.8 | 11.3 | 14.4 | 15.7 | 14.0 | 13.6 | 18.0 | 13.6 | 19.9 | 13.7 | 17.0 | 20.5 | 9.9 | 12.5 | 13.2 | 16.1 | 13.5 | 6.3 | 6.4 | 17.6 | 19.1 | 12.8 | 15.5 | 16.3 | 15.2 | 14.6 | 19.1 | 14.4 | 21.4 | 15.1 | 19.6 | 21.7 | 11.3 | 15.0 | 14.3 | 16.8 | 14.0 | 6.8 | 8.2 | 19.9 | 20.4 | 14.6 | 16.4 | 18.7 | 16.8 | 15.8 | 20.4 | 15.8 | 22.4 | 16.2 | 20.3 | 23.4 | 12.1 | 15.5 | 15.4 | 18.4 | 15.7 | 10.2 | 8.9 | 21.0 |
* Moyenne
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print("Moyenne:", round(np.mean(a),2))
print(x)
: Moyenne: 14.11
* Minimum
print("Minimum:", min(a))
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
: Minimum: 2.8
plt.tight_layout()
* Maximum
print("Maximum:", max(a))
[[file:./cosxsx.png]]
: Maximum: 23.4
Vous remarquerez le paramètre ~:exports results~ qui indique que le cod
e
* Médian
e
print("Médiane:", round(np.median(a),2))
: Médiane: 14.5
compréhensible sur GitLab.
* Écart-type
print("Écart-type:", round(np.std(a, ddof=1),2))
: Écart-type: 4.33
