no commit message
parent 61e39349
"cells": [], "cells": [
"# Etudier une liste de nombres"
"execution_count": 1,
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]"
"Tout d'abord il faut calculer la **moyenne**"
"execution_count": 7,
"moyenne : 14.113000000000001\n",
"écart-type : 4.334094455301447\n",
"min : 2.8\n",
"max : 23.4\n",
"médiane : 14.5\n"
"import numpy as np\n",
"print(\"moyenne : \", np.mean(data))\n",
"print(\"écart-type : \",np.std(data, ddof=1))\n",
"print(\"min : \",np.min(data))\n",
"print(\"max : \",np.max(data))\n",
"print(\"médiane : \", np.median(data))"
"execution_count": 5,
"scrolled": false
"4.334094455301447"
"source": []
"execution_count": null,
"source": []
"Calculer la moyenne et l'écart-type, le min, la médiane et le max des données suivantes :"
"metadata": { "metadata": {
...@@ -16,10 +102,9 @@ ...@@ -16,10 +102,9 @@
"nbformat": 4, "nbformat": 4,
