f5c490e9182da42b1c30e92aadd353a4
5424c37c
5424c37c
Alexandre Jesus
Make exercise 3
2801306f
36 additions
68 deletions
+36
-68
exercice_R_en.org
module2/exo3/exercice_R_en.org
+36
-68
5424c37c
#+TITLE: Your title
#+TITLE: Plots in org mode
#+AUTHOR: Your name
#+DATE: Today's date
#+LANGUAGE: en
#+LANGUAGE: en
* Plotting
First we put the dataset in a variable
#+BEGIN_SRC R :results output :exports src :session *R*
y <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9,
10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8,
* Some explanations
15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4,
17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1,
4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6,
18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2,
16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3,
https://orgmode.org/guide/.
15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3,
15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6,
16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3,
23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
df <- data.frame(x = seq(0, length(y)-1), y = y)
#+END_SRC
Like we showed in the video, R code is included as follows (and is
exxecuted by typing ~C-c C-c~):
print("Hello world!")
: [1] "Hello world!"
And now the same but in an R session. This is the most frequent
** Sequence plot
situation, because R is really an interactive language. With a
session, R's state, i.e. the values of all the variables, remains
persistent from one code block to the next. The code is still executed
using ~C-c C-c~.
#+BEGIN_SRC R :results output graphics :exports both :file ./sequence_plot.png :width 600 :height 400 :session *R*
library(ggplot2)
ggplot(df, aes(x = x, y = y)) +
geom_line() +
theme_bw()
#+END_SRC
: speed dist
[[file:./sequence_plot.png]]
: Min. : 4.0 Min. : 2.00
: 1st Qu.:12.0 1st Qu.: 26.00
: Median :15.0 Median : 36.00
: Mean :15.4 Mean : 42.98
: 3rd Qu.:19.0 3rd Qu.: 56.00
: Max. :25.0 Max. :120.00
plot(cars)
** Histogram plot
[[file:./cars.png]]
#+BEGIN_SRC R :results output graphics :exports both :file ./histogram_plot.png :width 600 :height 400 :session *R*
library(ggplot2)
ggplot(df, aes(x = y)) +
geom_histogram(bins=10) +
transparent and reproducible.
theme_bw()
#+END_SRC
the org document. It's a plain file, here named ~cars.png~. You have
[[file:./histogram_plot.png]]
understandable on GitLab.
quickly create code blocks in R by typing ~<r~ or ~<R~ followed by
~Tab~.
