Commit 496f580a authored by Dorinel Bastide's avatar Dorinel Bastide
Final minor changes, managed to obtained indeed solution results as per questions
parent 362372f2
...@@ -44,6 +44,7 @@ A method that is easier to understand and does not make use of the $\sin$ functi ...@@ -44,6 +44,7 @@ A method that is easier to understand and does not make use of the $\sin$ functi
import matplotlib import matplotlib
matplotlib.use('Agg') matplotlib.use('Agg')
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
np.random.seed(seed=42) np.random.seed(seed=42)
N = 1000 N = 1000
x = np.random.uniform(size=N, low=0, high=1) x = np.random.uniform(size=N, low=0, high=1)
...@@ -69,7 +70,6 @@ C:/Users/Utilisateur/mooc-rr/module2/exo1/PictureRes.png]] ...@@ -69,7 +70,6 @@ C:/Users/Utilisateur/mooc-rr/module2/exo1/PictureRes.png]]
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1: It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1:
#+begin_src python :results output :session *python* :exports both #+begin_src python :results output :session *python* :exports both
4*np.mean(accept) 4*np.mean(accept)
#+end_src #+end_src
