Modules3/exo1/Hengkuan
parent 7a428eae
"cells": [], "cells": [
"execution_count": 1,
"Standard Deviation: 4.3124\n",
"Minimum: 2.8\n",
"Median: 14.5\n",
"Maximum: 23.4\n"
"import numpy as np\n",
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,\n",
" 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2,\n",
" 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0,\n",
" 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6,\n",
" 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0,\n",
" 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4,\n",
" 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"# Calculate statistics\n",
"std_dev = np.std(data)\n",
"minimum = np.min(data)\n",
"median = np.median(data)\n",
"maximum = np.max(data)\n",
"print(f\"Standard Deviation: {std_dev:.4f}\")\n",
"print(f\"Minimum: {minimum:.1f}\")\n",
"print(f\"Median: {median:.1f}\")\n",
"print(f\"Maximum: {maximum:.1f}\")"
"execution_count": 3,
"Average (Mean): 14.1130\n",
"Minimum: 2.8\n",
"Median: 14.5\n",
"Maximum: 23.4\n"
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"# 计算统计量\n",
"mean = np.mean(data)\n",
"# 输出结果(保留适当小数位)\n",
"print(f\"Average (Mean): {mean:.4f}\") # 平均值保留4位小数\n",
"execution_count": null,
"source": []
"metadata": { "metadata": {
...@@ -16,10 +100,9 @@ ...@@ -16,10 +100,9 @@
"nbformat": 4, "nbformat": 4,
This diff is collapsed.
