Commit 067d8829 authored by Laurence Farhi's avatar Laurence Farhi
merge/request Version anglaise
parent 7eadfca3
# -*- mode: org -*-
#+TITLE: Perform a Merge/Request in Gitlab to update your mooc-rr repository
#+AUTHOR: Laurence Farhi
#+DATE: April, 2019
#+STARTUP: overview indent
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
This document explains how to retrieve from your GitLab repository the resource changes required for the exercise5 of Module 2.
To do this, we ask you to validate a Merge request with all the modifications made by Konrad, following the procedure below.
Go to your Gitlab workspace, from the page [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5571950188c946e790f06d4bc90fb5f6]["Your Gitlab space"]]
Follow the instructions below.
[[file:MergeRequest_images/MergeRequest1.png]]
You can see that there is a request for Merge pending.
[[file:MergeRequest_images/MergeRequest2.png]]
Select the Merge request.
[[file:MergeRequest_images/MergeRequest3.png]]
If you have meanwhile modified one of the files, Gitlab will warn you that there is a conflict (grey button with "!'') and will propose you to do the merge manually. Let you be guided...
If you go to mooc-rr/module2/exo5, you should see that 4 files have been modified.
[[file:MergeRequest_images/MergeRequest4.png]]
Then, if you follow the Jupyter path, you must also apply the changes in your Jupyter space.
To do this, go to your Jupyter space, from [[https://www.fun-mooc.fr/courses/course-v1:inria+41016+session02/jump_to_id/5310b948b605466d95b47e0676cf1069]["exercice 5 of Module 2"]]
(bouton "Read the analysis").
Make a "Git pull" to update your Jupiter space.
[[file:MergeRequest_images/MergeRequest5.png]]
When you read the notebook again (reload it), you should see the following change:
[[file:MergeRequest_images/MergeRequest6.png]]
......@@ -36,6 +36,7 @@ Pour cela, rendez-vous sur votre espace Jupyter, depuis [[https://www.fun-mooc.f
(bouton "Lire l'analyse").
Faites un "Git pull" pour mettre à jour votre espace Jupiter.
Quand vous lisez à nouveau le notebook (quittez la page et rechargez), vous devez voir la modification suivante :
