Learning Lab
1635efcd
Commit
1635efcd
by
Konrad Hinsen
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
init.el pleinement compatible avec orgmode 9.2
parent
cff12ba6
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
94 additions
and
66 deletions
+94
-66
init.el
module2/ressources/rr_org/init.el
+46
-33
init.org
module2/ressources/rr_org/init.org
+48
-33
No files found.
View file @
1635efcd
@@ -227,51 +227,64 @@ Entered on %U
setq
org-src-preserve-indentation
t
setq
t
require
'org-tempo
nil
t
setq
rrmooc/new-org-templates
version<=
"9.2"
org-version
when
require
'org-tempo
add-to-list
'org-structure-template-alist
require
'subr-x
"s"
"#+begin_src ?\n\n#+end_src"
"<src lang=\"?\">\n\n</src>"
defun
rrmooc/add-org-template
old-style-template
add-to-list
if
cons
first
old-style-template
string-trim-right
substring
second
old-style-template
8
-9
old-style-template
unless
;; this template is predefined in the new templating system
"s"
add-to-list
"m"
"#+begin_src emacs-lisp :tangle init.el
\n\n#+end_src"
"<src lang=\"emacs-lisp\">\n\n</src>"
"m"
\n\n#+end_src"
add-to-list
"r"
"#+begin_src R :results output :session *R* :exports both\n\n#+end_src"
"<src lang=\"R\">\n\n</src>"
"r"
add-to-list
"R"
"#+begin_src R :results output graphics :file (org-babel-temp-file \"figure\" \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src"
"R"
add-to-list
"RR"
"#+begin_src R :results output graphics :file (org-babel-temp-file (concat (file-name-directory (or load-file-name buffer-file-name)) \"figure-\") \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src"
"RR"
add-to-list
"p"
"#+begin_src python :results output :exports both\n\n#+end_src"
"<src lang=\"python\">\n\n</src>"
"p"
add-to-list
"P"
"#+begin_src python :results output :session :exports both\n\n#+end_src"
"P"
add-to-list
"PP"
"#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both\nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nmatplot_lib_filename\n#+end_src"
"PP"
if
memq
system-type
windows-nt
ms-dos
if
memq
system-type
windows-nt
ms-dos
;; Non-session shell execution does not seem to work under Windows, so we use
;; a named session just like for B.
add-to-list
"b"
"#+begin_src shell :session session :results output :exports both\n\n#+end_src"
"<src lang=\"sh\">\n\n</src>"
"b"
add-to-list
"b"
"#+begin_src shell :results output :exports both\n\n#+end_src"
"b"
add-to-list
"B"
"#+begin_src shell :session *shell* :results output :exports both \n\n#+end_src"
"B"
add-to-list
"g"
"#+begin_src dot :results output graphics :file \"/tmp/graph.pdf\" :exports both
"g"
digraph G {
digraph G {
node [color=black,fillcolor=white,shape=rectangle,style=filled,fontname=\"Helvetica\"];
A[label=\"A\"]
A[label=\"A\"]
B[label=\"B\"]
B[label=\"B\"]
A->B
A->B
}\n#+end_src"
"<src lang=\"dot\">\n\n</src>"
}\n#+end_src"
global-set-key
kbd
"C-c S-t"
'org-babel-execute-subtree
global-set-key
kbd
"C-c S-t"
View file @
1635efcd
@@ -83,7 +83,7 @@ document, simply =M-x org-babel-tangle=.
("melpa-stable" . 10)))
#+END_SRC
#+END_SRC
* Install missing packages
:tangle init.el
(dolist (pkg '(ess
(dolist (pkg '(ess
auctex
auctex
htmlize
htmlize
@@ -92,7 +92,7 @@ document, simply =M-x org-babel-tangle=.
(package-install pkg)))
#+end_src
#+end_src
* Import environment variables
:tangle init.el
(exec-path-from-shell-initialize)
(exec-path-from-shell-copy-env "PYTHONPATH")
#+end_src
#+end_src
@@ -366,57 +366,72 @@ Additional shortcuts for navigating through org-mode documents:
** Adding source code blocks: :LUKA:
*** Enable the old template system with Orgmode 9.2 and later
(require 'org-tempo nil t)
(setq rrmooc/new-org-templates (version<= "9.2" (org-version)))
(when rrmooc/new-org-templates
(require 'org-tempo))
#+end_src
*** Template definitions that work with the old and new templating systems
(require 'subr-x)
(defun rrmooc/add-org-template (old-style-template)
(add-to-list 'org-structure-template-alist
(if rrmooc/new-org-templates
(cons
(first old-style-template)
(string-trim-right (substring (second old-style-template) 8 -9)))
old-style-template)))
#+end_src
#+end_src
*** With capital letters:
To use this type <s and then TAB
(unless rrmooc/new-org-templates
'("s" "#+begin_src ?\n\n#+end_src" "<src lang=\"?\">\n\n</src>"))
(rrmooc/add-org-template
'("s" "#+begin_src ?\n\n#+end_src" "<src lang=\"?\">\n\n</src>")))
#+end_src
#+end_src
*** Emacs-elisp code:
To use this type <m and then TAB
'("m" "#+begin_src emacs-lisp :tangle init.el
\n\n#+end_src" "<src lang=\"emacs-lisp\">\n\n</src>"))
#+end_src
#+end_src
*** R code:
*** R code:
To use this type <r and then TAB. This creates an R block for textual output.
'("r" "#+begin_src R :results output :session *R* :exports both\n\n#+end_src" "<src lang=\"R\">\n\n</src>"))
#+end_src
#+end_src
To use this type <R and then TAB. This creates an R block for graphics
that are stored in the =/tmp/=.
'("R" "#+begin_src R :results output graphics :file (org-babel-temp-file \"figure\" \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src" "<src lang=\"R\">\n\n</src>"))
#+end_src
#+end_src
To use this type <RR and then TAB. This creates an R block for
graphics that are stored in the directory of the current file.
'("RR" "#+begin_src R :results output graphics :file (org-babel-temp-file (concat (file-name-directory (or load-file-name buffer-file-name)) \"figure-\") \".png\") :exports both :width 600 :height 400 :session *R* \n\n#+end_src" "<src lang=\"R\">\n\n</src>"))
#+end_src
#+end_src
*** Python code
*** Python code
To use this type <p and then TAB
'("p" "#+begin_src python :results output :exports both\n\n#+end_src" "<src lang=\"python\">\n\n</src>"))
#+end_src
#+end_src
'("P" "#+begin_src python :results output :session :exports both\n\n#+end_src" "<src lang=\"python\">\n\n</src>"))
#+end_src
#+end_src
'("PP" "#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file \"figure\" \".png\") :exports both\nimport matplotlib.pyplot as plt\n\nimport numpy\nx=numpy.linspace(-15,15)\nplt.figure(figsize=(10,5))\nplt.plot(x,numpy.cos(x)/x)\nplt.tight_layout()\n\nplt.savefig(matplot_lib_filename)\nmatplot_lib_filename\n#+end_src" "<src lang=\"python\">\n\n</src>"))
#+end_src
#+end_src
*** Bash "sh" code:
*** Bash "sh" code:
To use this type <b and then TAB
@@ -424,28 +439,28 @@ To use this type <b and then TAB
(if (memq system-type '(windows-nt ms-dos))
'("b" "#+begin_src shell :session session :results output :exports both\n\n#+end_src" "<src lang=\"sh\">\n\n</src>"))
'("b" "#+begin_src shell :results output :exports both\n\n#+end_src" "<src lang=\"sh\">\n\n</src>")))
#+end_src
#+end_src
To use this type <B and then TAB. This comes with a session argument
(e.g., in case you want to keep ssh connexions open).
'("B" "#+begin_src shell :session *shell* :results output :exports both \n\n#+end_src" "<src lang=\"sh\">\n\n</src>"))
#+end_src
#+end_src
*** Graphviz
*** Graphviz
'("g" "#+begin_src dot :results output graphics :file \"/tmp/graph.pdf\" :exports both
digraph G {
digraph G {
A[label=\"A\"]
A[label=\"A\"]
B[label=\"B\"]
B[label=\"B\"]
A->B
A->B
}\n#+end_src" "<src lang=\"dot\">\n\n</src>"))
#+end_src
#+end_src
** Evaluating whole subtree: :LUKA:
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
