Commit 1fe6c72d authored by Arnaud Legrand's avatar Arnaud Legrand
Unbelievable! :( The unif rng seem to have changed from a version of R
to an other...
When rerunning this code on my laptop which has been recently
upgraded, the beginning of the sequence of randomly generated values
is clearly different. I should have recorded the version numbers... :)
parent 16ce0c54
......@@ -129,6 +129,32 @@ df$Malade = sapply(df$Age, function(x) rbinom(n=1,size=1,prob=proba(x)))
Le chargement a nécessité le package : lattice
Le chargement a nécessité le package : survival
Le chargement a nécessité le package : Formula
Le chargement a nécessité le package : ggplot2
Attachement du package : ‘Hmisc’
The following objects are masked from ‘package:base’:
format.pval, units
Attachement du package : ‘dplyr’
The following objects are masked from ‘package:Hmisc’:
src, summarize
The following objects are masked from ‘package:stats’:
filter, lag
intersect, setdiff, setequal, union
summary(df)
......@@ -137,16 +163,16 @@ str(df)
Age Malade
Min. :22.01 Min. :0.00
1st Qu.:37.06 1st Qu.:0.00
Median :53.30 Median :1.00
Mean :52.42 Mean :0.53
3rd Qu.:66.29 3rd Qu.:1.00
Max. :79.36 Max. :1.00
'data.frame': 100 obs. of 2 variables:
Age Malade
Min. :22.01 Min. :0.000
1st Qu.:35.85 1st Qu.:0.000
Median :50.37 Median :1.000
Mean :50.83 Mean :0.515
3rd Qu.:65.37 3rd Qu.:1.000
Max. :79.80 Max. :1.000
'data.frame': 400 obs. of 2 variables:
$ Age : num 75.1 76.4 38.6 70.2 59.2 ...
$ Malade: int 1 1 0 1 0 0 1 0 1 1 ...
$ Malade: int 1 1 0 1 1 1 0 0 1 1 ...
Voici une représentation graphique des données qui permet de mieux
