Learning Lab
29494a84
Commit
29494a84
by
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'master' of gitlab.inria.fr:learninglab/mooc-rr/mooc-rr-ressources
parents
64fdefc9
78f4b088
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
10 additions
and
5 deletions
+10
-5
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+10
-5
No files found.
View file @
29494a84
@@ -239,12 +239,17 @@ There are two situations in which it might be necessary to modify
If you do have to modify =init.el=, check the comments at the
beginning of the file for instructions.
** Step 5: Check whether the installation is working or not
Quit Emacs if it is running, and start it again. This first start
will
will
take a bit of time because Emacs will download a few add-on
packages. For that reason, please make sure that you have a working
internet connection for this step.
internet connection for this step. Note also that the download can
fail for other reasons, such as the package servers being overloaded.
Then open a file =foo.org=. Copy the following lines into this file:
Such situations do not last very long, so we recommend that you just
quit Emacs (=C-x C-c=, meaning =Ctrl + x= followed by =Ctrl + c=) and
restart it. At worst, repeat this until you get no more errors on
startup.
Next, open a file =foo.org=. Copy the following lines into this file:
: #+begin_src shell :session foo :results output :exports both
: ls -la # or dir under windows
: #+end_src
: #+end_src
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
