Commit 2b0c5668 authored by Konrad Hinsen's avatar Konrad Hinsen
Fix typo
parent 44ef48c4
...@@ -98,7 +98,7 @@ For advanced uses of Emacs, such as calling Emacs from a Makefile to automate do ...@@ -98,7 +98,7 @@ For advanced uses of Emacs, such as calling Emacs from a Makefile to automate do
Be aware that running Emacs the Unix way implies some subtle differences compared to running Emacs the macOS way. In particular, Emacs will inherit the shell's environment variables when run the Unix way, but the user session's environment variables when run the macOS way. Be aware that running Emacs the Unix way implies some subtle differences compared to running Emacs the macOS way. In particular, Emacs will inherit the shell's environment variables when run the Unix way, but the user session's environment variables when run the macOS way.
** Windows ** Windows
Download the precompiled Emacs 26, which is available [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-i686.zip][for 32 bits architectures]] or [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-x86_64.zip][for 64 bits architectures]]. The choice depends on your machine; if you don't know which is best, try the 64-bit version and if it cannot be started, switch to 32-bit. Unzip the zip file preserving the directory structure. If this approach does not work, follow the instructions from the [[https://www.gnu.org/software/emacs/download.html#windows][official emacs website]]. If this still fails, do not hesitate to ask questions on the forum. Download the precompiled Emacs 26, which is available [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-i686.zip][for 32 bit architectures]] or [[https://ftp.gnu.org/gnu/emacs/windows/emacs-26/emacs-26.1-x86_64.zip][for 64 bit architectures]]. The choice depends on your machine; if you don't know which is best, try the 64-bit version and if it cannot be started, switch to 32-bit. Unzip the zip file preserving the directory structure. If this approach does not work, follow the instructions from the [[https://www.gnu.org/software/emacs/download.html#windows][official emacs website]]. If this still fails, do not hesitate to ask questions on the forum.
Finally run =bin\runemacs.exe=. Alternatively, create a desktop shortcut to =bin\runemacs.exe=, and start Emacs by double-clicking on that shortcut's icon. See [[https://www.gnu.org/software/emacs/manual/html_node/emacs/Windows-Startup.html][here]] for an explanation of this and other methods for launching Emacs under Windows. You should be able to obtain a window that looks like this: Finally run =bin\runemacs.exe=. Alternatively, create a desktop shortcut to =bin\runemacs.exe=, and start Emacs by double-clicking on that shortcut's icon. See [[https://www.gnu.org/software/emacs/manual/html_node/emacs/Windows-Startup.html][here]] for an explanation of this and other methods for launching Emacs under Windows. You should be able to obtain a window that looks like this:
#+BEGIN_CENTER #+BEGIN_CENTER
